c1 door striker mounting plate
http://i47.tinypic.com/otowwj.jpg
looking for help in sourcing the mounting plate that holds the door lock striker in place on a 56 corvette.
Body shop couldn't remove the seized screws and cut the piece out
thanks
That's a shame the shop cut that out, it was not necessary. It could have been removed from the rear if the gas tank was pulled. Anyhow, from here, your original plate can most likely still be saved. Drill out the screw heads to get the latch off and apply some heat to the screw studs while holding them with a Visegrips and they will come out. Mine took quite a bit of heat to remove so you want to do this on the bench. Pilot Dan
Not good. There are several ways to get that stuff out without doing that. Make sure that those guys now know that the location and thickness of that repair are critical to door/body alignment. Also, if it's not done correctly, it will crack the first time that you close the door. If it's too thick, or you need a combination of shims, then the screws won't be long enough. These are special screws with a 5/16" fine thread, and a very small phillips head (1 5/8" max). The replacement cage and nut plate are available from Grossmuellers Corvette
1-800-258-5362.
Mike Coletta
1-800-258-5362.
Mike Coletta
That really sux! I would make sure they don't do any more surgery with a chain saw.....
I would be thoroughly P^&&&D if anybody did that to my baby. Good luck!
