60 Glide to 4 Speed
60 Glide to 4 Speed
I have been putzing with my 60 for a while and been wondering what would be involved in converting the factory powerglide to a 4 speed.
Pros, cons, costs, advise?
Been there. Pretty straight forward but the most challenging part will be the installation of the cross shaft bracket on the frame. Do it with the cross shaft in place and the shaft moving freely to make sure it's at the right location.
You will also have to re-locate the dimmer switch and change the brake pedal.
Pierre
Pierre
1 Post
I don't think it's such a big deal. You need a 4-speed transmission, 4-speed shifter & linkage, 4-speed bell housing with a cross shaft, 4-speed console (not sure for a solid axle), 4-speed clutch assembly, 4-speed pedal assembly, correct carburetor, manual radiator (can use automatic radiator by plugging transmission oil lines), car lift, transmission lift, a little time, and a helper.
Of course, you will not have a original car anymore after changeover. Keep all your powerglide parts, just incase you want to go back to a automatic.
Good luck.
Good luck.
I don't it's such a big deal. You need a 4-speed transmission, 4-speed shifter & linkage, 4-speed bell housing with a cross shaft, 4-speed console (not sure for a solid axle), 4-speed clutch assembly, 4-speed pedal assembly, correct carburetor, manual radiator (can use automatic radiator by plugging transmission oil lines), car lift, transmission lift, a little time, and a helper.
Good luck.
Good luck.
Pierre
Not to derail the topic but since the car is not original I would strongly consider a 5-speed with overdrive.
Did that to my '60 a few years ago. I love it.
Just gather up all the stuff. You get to weld 2 items to the frame. If you are doing a Muncie, you need a weird looking rear adapter bracket.
I will go with a 5 speed, what one would you recommend and where to get it as well as the rest of the parts I will need.
Well I run the Tremec TKO-600 and have no complaints. The latest Keisler offering is the RS-6000 with nearly the same HP capacity, smoother shifts and smaller footprint (and somewhat cheaper) -- but the lead time to get one is problematic. My only complaint on the Tremec was the notchy 2-3 shifts when winding the car out. The trick is to push that shifter with an open hand directly at the TEMP **** in the center console and let the spring and detents do their job. Second nature to me now and no more missed shifts. So you'll have to decide what would work best for you.
Well - I should have more correctly stated their RS "Perfect Fit" series I guess:
http://www.keislerauto.com/vmchk/gm/...page_tabs.html
C2 of Year Finalist (performance mods) 2019
American Powertrain has a auto to 5 speed conversion. They offer the Tremec TKO 600 with their shifter. My TKO shifts perfect. They also offer two gear sets depending on your rear axle ratio. I have 1500 miles on my TKO and am extremely pleased. If I were you I would at least talk to them and compare what they have against the competition. In my opinion, the 5 speed is the best upgrade you can make to a C2.
Mark
Mark
Mark
Mark
Go for it!!!
Didn't mean to say that Keisler is the only choice...I talked to American Powertrain before my conversion and they are knowledgeable, friendly folks. At the time I think what swayed me was the Keisler kit had a nice reproduction C1 shifter setup..all else being equal. The 5-speed is a phenomenal improvement. You get a slightly deeper first and your car will cruise interstates at little more than a fast idle!
