How much hp with this build ?
• 540 CID
• World Products 4.500 Bore Blocks
• Brodex CNC 2X plus heads
• Scat super Lite Billet crank 4.250 stroke
• Scat H-Bead 6.585 rods
• J&E 11.2 to 1 F-pistons
• Crane roller cam and valve train 260 dur. 640 lift
• Weiand X manifold
• Holley 4150 1000CFM carb
• Holly electric fuel pump
• B&M oil cooler
• Oil pan 8 ½ quart
• Melling H - V oil pump
• Mallory unilite distributor
• 3:55 gears and pose rear end
• Hooker Headers into side exhaust
• Gymkhana (road race) Front and Rear springs
• KYB shocks
• Completely rebuilt suspension
• Fully adjustable rear alignment
• All hoses are braided steel
• Braided brake lines
• Power brakes
• Power steering
• 4 W.P.D.B vented and drilled rotors
• New gas tank
• 4-speed Muncie Transmission
• All new clutch, flywheel, throwout bearing new in 2009
• Aluminum Be Cool Radiator
• Electric Radiator Fan
• Aluminum water pump
• All engine bolts ARP
• Weiand X manifold
• B&M oil cooler
• Oil pan 8 ½ quart
• KYB shocks
• Power brakes
• Power steering
• New gas tank
Thanks for the reply.
I was told the build was close to 800 hp. It was built out west and I can't get ahold of builder, he has move on from the shop and no knows where he ended up. Just wanted to know more about the car.
