Advice on a Coolant Recovery Tank for 67 L71
Hello all,
So, first of all I know a coolant recovery tank wasn't factory for the 67 L71 435hp 427, nor was an expansion tank. However, despite originality I want to install one anyway. I drive this car (as it should be driven) and want to improve the cooling system because it gets in the low 100's F here in Sacramento, Ca. and the car pukes coolant on the ground when it gets on the warm side.(as it was designed to do from the factory)
The stock copper and brass radiator is on the shelf in a box and the new Ron Davis crossflow aluminum radiator is now sitting in it's place. The next thing to add is a small & descrete coolant recovery tank that looks to be period correct or will be hard to detect in the all stock engine compartment.
All that said, I'm looking for someone that may have already found or mounted a coolant recovery tank (plastic or metal) that doesn't look out of place in the compartment, or can be somewhat hidden. It needs to be easily removed as well as the car is bone stock with 54K miles on it and I don't want to add any mounting holes anywhere.
Any suggestions?
Doug
Any suggestions?
Doug
When I took mine to the track I had a zip tied an old quart bottle to the core support (to meet track requirement) as just a catch can. Not really what you want for the long term though. I've heard of guys using the SB's expansion tank but that requires holes and that is out of the question on a car like yours. Perhaps you could come up with a alternative method of mounting?
Received 6,993 Likes
2015 C2 of Year Finalist
if its puking coolant don't you think you have it over filled
I have never had the need for an expansion tank on either of my 427's, but the holes for the expansion tank mounting straps are already on the inner fender even on big block cars. They were filled from the factory but could easily be used to mount a small block expansion tank for a factory-appearing installation.
The aluminum expansion tanks fitted to some small block Corvettes are not suitable to be used as coolant recovery tanks without considerable modification- there's better alternatives from the Summit and Jeg's etc catalogues. I think it's pointless to add a recovery tank, but it's not my car.
Anyone know why the engineers did the BB's this way? It seems like a No-Brainer to take advantage of about 50 sq in of unused cooling capacity. Any downside other than originality?
