Lubricate tachometer and speedometer cable. What to use and how much?
Old 06-25-2012, 11:15 AM
TheSaint
Support Corvetteforum!
TheSaint's Avatar
Default Lubricate tachometer and speedometer cable. What to use and how much?
What do you use when you lubricate the tachometer and speedometer cable?
Also how much lube do you use on the tacho(i do not want the lube getting inside the gauge)
Old 06-25-2012, 12:24 PM
54greg
54greg's Avatar
The lube migrates up so I apply at the distributor or trans end and not to the last 5 inches. Cable lube purchased from Corvette Central works great and I've also used wheel bearing grease with good results.
Old 06-25-2012, 12:41 PM
Mike67nv
Mike67nv's Avatar
2018 C2 of Year Finalist
2015 C2 of the Year Finalist
I like KABLE-EASE by AGS. I get it from Ace Hardware here. It’s a graphite based lube that comes in a .5oz tube for under $3. Use it sparingly. One tube is enough to lube your tach and speedo several times.
http://www.agscompany.com/lubricants/automotive/160
Old 06-25-2012, 12:54 PM
TheSaint
TheSaint's Avatar
54greg. The lube from CorvetteCentral is that also white Lithium grease?
Mike67nv. I see so it is white lithium grease that is the thing to use for lubrication
Old 06-25-2012, 01:00 PM
Mike67nv
Mike67nv's Avatar
Mike67nv. I see so it is white lithium grease that is the thiing to use for lubrication
No, it's a graphite based lube - more like an oil than grease - and it's black. I pull the cables out from the cluster end.
Old 06-25-2012, 01:04 PM
65 vette dude
65 vette dude's Avatar
A speedo shop told me they use nothing but a thin coat of wheel bearing grease. They also warned me not to use white lithium grease. As mentioned above, don't lube the last 6 inch's of cable on the end where it goes into gauges. You can also purchase those 90 degree elbow connectors that goes on the distributor, and the tranny, that helps smooth out the bends in the cables. They have zert fitting on them that makes lubing the cables a 5 minute job.
Old 06-25-2012, 01:16 PM
Bluestripe67
Bluestripe67's Avatar
Received 2,127 Likes on 1,466 Posts
Using a 90 degree device at the distributor is a clear indicator that it is NOT phased correctly. Dennis
Old 06-25-2012, 03:44 PM
TheSaint
TheSaint's Avatar
I thought that when lubricate the tachometer cable you just loosened the cable on the distibutor and put a small amount of lube in there
Somehow i thought that the lube would work its way towards the gauge
Old 06-25-2012, 03:55 PM
54greg
54greg's Avatar
Not alternator, I think you mean distibutor. You need to pull the cable out and lube all but the last 5-6 inches of the gauge side end.
Old 06-25-2012, 04:02 PM
TheSaint
TheSaint's Avatar
Of course i mean the distibutor. I suppose it would work kind of strange hooking the tacho cable to the alternator. It have to be a long cable as well
Thanks for telling me
Old 06-25-2012, 04:10 PM
Ron Miller
Ron Miller's Avatar
Also, in case it hasn't been mentioned, both the speedometer and tachometer cable housings have to be disconnected at the instrument cluster in order to remove the cables for lubrication. Not a job I look forward to . . . . .
Old 06-25-2012, 04:52 PM
TheSaint
TheSaint's Avatar
Okay i see. I suppose that you must take out the cluster to be able to loosen the speedo and tacho cable so that makes it a little more work
I borrowed this picture from Jackfit on how he does it to get access behind the cluster. I suppose doing it like Jack saves quite some work?
How often do you lube the cables?
Old 06-25-2012, 05:05 PM
isac
isac's Avatar
If you get a 90´ adapter on the tranny It's a piece of cake to lube the cable as mentioned earlier , no need to remove the cable from the cluster
Get a spare adapter for the tach when you lube that cable and remove it when your'e done.
I had a "whirring" sound and a jumping needle in my tach and 1 shot with a grease gun was enough.
Old 06-25-2012, 05:12 PM
TheSaint
TheSaint's Avatar
Who sells that adapter?
Old 06-26-2012, 12:49 PM
isac
isac's Avatar
I think most vendors have them but I got mine from here , more info here
Peter
Old 06-28-2012, 11:50 AM
abe g
abe g's Avatar
Default Plain dengine oil for speedometer and tach cable
As the original owner of a 63swc I have had one speedometer cable replacement in all these years. Since then I used engine oil (30) once or twice to lube these cables. Keep the kinks out of your cables and this will be more than satisfactory. Regards, Abe G
Old 06-28-2012, 01:20 PM
INMYBLOOD
INMYBLOOD's Avatar
Location: The problem is all inside your head she said to me.
Hey, that's the way my original was. Tach was from the back of the Generator through a gear reduction unit to the gauge. Electronics made all the mechanical parts unnecessary.
To Lubricate tachometer and speedometer cable. What to use and how much?
Old 06-28-2012, 01:35 PM
wmf62
wmf62's Avatar
St. Jude Donor '07
AND, they make/made a tach drive alternator that some on the forum have used as a replacement for their tach drive generators.
Bill
Old 06-29-2012, 11:43 AM
TheSaint
TheSaint's Avatar
Much of the reason i ask about this is because that since i bought my car back in 1993 and i have never lubed either the tacho or speedo cable.
Never had any problems and they work perfect.
Now that i see how often you lube the cables i suppose it is time for me to do that job
Old 06-29-2012, 10:43 PM
mike16
mike16's Avatar
lots of cables in aircraft. Aircraft spruce and specialty Inc sels an FAA aproved cable lube that works in very hot and very cold climates.
Quick Reply: Lubricate tachometer and speedometer cable. What to use and how much?
