can you emulate an LS engine using a Gen I block....
St. Jude Donor '07
i realize the LS parts won't fit a Gen I, but can similar heads/pistons/intakes/electronics be used to get the wizzbang of an LS engine?
Bill
Bill
St. Jude Donor '07
there may be a lot more improvements that are possible for a Gen I engine if one thinks outside the box.
Bill
the real question is 'why not'.... in my simple mind it's a heck of a lot more cost effective and easier than the conversions required to fit an LS in a C1,2,3 or 4.
Bill
Bill
Why mess with success?
Buy a street rod to play with.
Chuck
Bill,
Motown makes a block that accepts LS heads and intakes. Here's an old article on it:
http://www.hotrod.com/techarticles/e...e/viewall.html
DT
DT
Bill,
DT
DT
AND, they also say that "busy hands are happy hands".
Knowing you, it looks like a new power plant is in your future.
Gotta keep those hands busy.
Chuck
Bill, you need to buy ANOTHER project.
Can't keep messin' with the same one. "Put a fork in it. It's done".
And, since I'm quoting a lot of old adages in this thread..............
"If it ain't broke, don't fix it".
Chuck
You can get can get computer controlled EFI and after market heads for a Gen 1 small block and get similar performance to an LS motor. The down side is the parts are kind of pricey. The upside is there will be fewer electronic and computer glitches than an LS installation.
Popular Hot Rodding has a good series of articles on Building The Anti-LS Motor. They build a Gen 1 SBC and with high quality after market products and get performance numbers better than an LS crate motor.
LS conversions are heavily documented during the installation. Problems after the installation are not documented as well. Engine management problems can be difficult to identify and expensive to fix.
Im not knocking LS motors and my next build will use one. Im just saying they can have their own set of problems.
St. Jude Donor '07
Bill
Of course you can hod rod just about any engine to get HP/torque improvements. Economy and efficiency (and quality) improvements will likely require more than the Gen 1 engine is capable of. The LS bottom end is considerably stiffer than the Gen 1. The stiffness allows for much better high RPM operation. And the LS uses materials and coatings that cannot be used in the older design. Sure some of the technologies can be utilized, but you won't get the total system to perform like an LS without virtually making it an LS.
The LS motor has a wider V angle allowing for larger heads and better airflow. Besides a performance advantage from bigger heads, the rest is simply computer controlled timing and fuel injection. An SBC with computer controlled EFI can get equivalent fuel economy to an LS motor.
