running out of gas
running out of gas
out for a run 2 weeks ago, outside temp was 85 deg F and sunny/hot, drove 35 miles and out of the blue the engine looses power and feels like it's running out of fuel, I feathered the gas and she came back to life and drove another 10 miles or so no problem. Stopped for lunch, started back up fine and drove about 20 miles and it started again, this time she stalled. 1 of the guys in our group said to try pouring water on the fuel pump, fuel lines didn't feel overly hot but after 5 mins she started back up again and ran fine for another 25 miles or so then she started losing power again, this time was able to feather the gas pedal and she came back to life and we made it home. The next day I took it out and beat on it and had no problems, drove it about 20 miles. Then last Monday, anther hot humid day and we took it for a cruise over to the next town, coming home we were coming up a long hill and I pushed the pedal down enough to load the engine and she started starving for fuel again but feathered it back to life and made it home fine, had the car for 3 years and this has never happened before,,,,any ideas? The hottest temp I could find on the fuel system was 185 deg F on the outlet of the fuel pump....
Received 4,583 Likes
C1 of Year Finalist (appearance mods) 2019
Sounds to me like a clogged pickup/fuel line or a pump on it's way out. Check the out put pressure at the carb. Have you used any fuel system cleaner in it ever? Could be the crappy gas nowadays clogging up the carb, pickup, or pump.
How hot were the fuel bowls?
Received 1,845 Likes
Loosen the gas cap and try again.
Check the filter in the tank, inline between pump and carb and in the carb inlets.
Received 2,147 Likes
What type of gas are you running? Anything with ethonal? I think your gas is boiling, vapor lock.. Dennis
thanks for the tips guys, a few good ideas to try...I have ordered some gas line insulation from summits just in case but my fuel line routing isn't really that close to the headers
Had symptoms like that one time on a GM sbc in an '87 Firebird. Turned out the pivot rod for the pump lever arm had worn an oblong shape in its mounting holes in the pump body. The pump still functioned, pressure was good, but volume was intermittently reduced when the rod shifted around.Drove me crazy trying to figure it out, tried everything else - filter, carb cleaning, tank pick up sock, etc. Finally gave up and pulled the pump out of desperation, and saw the problem!
Octane booster will have no effect on vapour lock, if that's what the issue is.
If all the ideas so far don't make any difference, might want to look into a weak ignition coil or bad points/condenser.
One way to check it is to stick your hand down in the tank and feel of it. Another way is to unhook the line going to the pump and let the gas siphon out of the rubber hose, if it comes out in a steady stream, your tank sock is okay.
No gas in Canada has more that 10% ethanol, excepting E85 which is in specially marked pumps so it's not accidentally pumped into non-flex fuel cars.
thanks Mike, I'm running a MSD system but i do recall reading lately about some coils getting hot and acting up
thanks Mike, 1 person reco'd blowing back to the tank from the inlet line to the pump, is this wise? Of course I would remove the gas cap first
