No good low down dirty rotton battery disconnects
Old 06-09-2012, 01:41 PM
dplotkin
Support Corvetteforum!
dplotkin's Avatar
Received 2,130 Likes on 1,030 Posts
2015 C2 of the Year Finalist
Default No good low down dirty rotton battery disconnects
After 12 years with these dastardly things one would think I learned by now. Those cheap-*** green handled quick-disconnects are no good. Don't use them. This morning, car cranks, fires, and dies, almost like a failed ballast resistor. Had me befuddled there for a second. Thought to myself, oh no, TI ignition failure. But it turned out to be that FOR SH&%T quick dissconnect.
The crappy connection would weld itself enough to spin the starter, but once released not enough to run the ignition. Tighten it up more, runs fine. What are you guys using? Knife style? I don't like the ones that come apart.
Dan
Old 06-09-2012, 01:47 PM
6T5RUSH
6T5RUSH's Avatar
Cruise-In III Veteran
Dan,
Using the knife type for the last 2 years..no issues. Getting 12 years out of anything I think you're doing good.
Jim
In God We Trust!
Old 06-09-2012, 01:53 PM
oldsarge
oldsarge's Avatar
I have been using the green **** dissconnect for about 7 years with no problem. Maybe after 12 years it is time for them to wear out. After 12 years, I think you got your monies worth. But now that I know you had a problem with yours, I might go and buy a new one. JMTC
Old 06-09-2012, 02:08 PM
magicv8
magicv8's Avatar
Originally Posted by dplotkin
After 12 years with these dastardly things one would think I learned by now. Those cheap-*** green handled quick-disconnects are no good. Don't use them. What are you guys using?
Dan
I've been using a green **** for 8 years with no problems since I got an Optima battery. Had 2 green ***** in the 8-10 years before that and they had to be replaced with the battery boxes when the standard batteries cracked in the heat of the engine bay (1 delco, 1 Exide).
Old 06-09-2012, 02:09 PM
Powershift
Powershift's Avatar
Received 1,681 Likes on 1,307 Posts
The knife blade type of disconnect seems to be much more reliable, and generally gets better positive/approval ratings. But they are more cumbersome to install in the car.
The green **** type gets mixed reviews. But you need to be aware that there is a USA made disconnect and an off-shore (China) made disconnect. I have one of the older ones from USA and it seems to work well. You can find these if you search a bit. I DO NOT RECOMMEND the imported ones for obvious reasons.
Larry
Old 06-09-2012, 02:12 PM
Bill Lacy
Bill Lacy's Avatar
Switched to the knife type about 15 years ago and have never had any trouble....
Old 06-09-2012, 02:33 PM
midyearvette
midyearvette's Avatar
10 years or more here with no issues at all......green ****......
Old 06-09-2012, 02:41 PM
Kerrmudgeon
Kerrmudgeon's Avatar
Received 4,583 Likes on 2,157 Posts
C1 of Year Finalist (appearance mods) 2019
Originally Posted by midyearvette
10 years with green ****......
See a doctor Frank....
Old 06-09-2012, 02:45 PM
corvetteed
corvetteed's Avatar
St. Jude Donor '14-'15-'16-'17-'18-'19-'20-'21-'22-'23-'24
Have the knife type on 4 of my cars, for over a dozen years; no problems at all.
Old 06-09-2012, 03:45 PM
5thvet
5thvet's Avatar
7 years with mine and no problems ( yet!)......
Old 06-09-2012, 03:52 PM
Plasticman
Plasticman's Avatar
Since at least 1986 with the green ***** (on several vehicles), with only one issue - I did not tighten it enough (that time).
Doc's say I will survive with the green ***** (based on past history)..........
Plasticman
Old 06-09-2012, 05:25 PM
wolfman64
wolfman64's Avatar
2020 C1 of the Year Finalist - Modified
Dan,
I installed a solenoid in my '64 restomod that is remote controlled from my key FOB. See attached picture. It's really sweet to be able to just click a button and disconnect the battery. The GPS locating device and alarm are wired around it. It provides another level of anti-theft protection as a non-start feature as well as an absolute disconnect during storage or trickle charge periods.
Wolfman
Old 06-09-2012, 05:33 PM
65hihp
65hihp's Avatar
Received 3,269 Likes on 1,690 Posts
green ****, no problems 3.5 years. Lots of things drive me nuts, but the green **** disconnect is not one of them. If I ever did have a problem with it, I would unscrew ****, wire brush the threads and add a touch of lite grease. No need to make any changes...
ps, slick setup wolfman, but not for me. pps, thanks again for the parts.
Old 06-09-2012, 05:41 PM
KC John
KC John's Avatar
C2 of Year Finalist (appearance mods) 2019
Originally Posted by wolfman64
Dan,
Wolfman
My car is set up the same way and I couldn't be happier. It's so easy to use, I disconnect the power to the entire car every time I shut the car off. No need to raise the hood.
Old 06-09-2012, 06:12 PM
midyearvette
i did and asked for a second opinion, he said "okay, youre' ugly too!"
quote Rodney........
Old 06-09-2012, 06:14 PM
wmf62
wmf62's Avatar
St. Jude Donor '07
i don't understand how you can have enough amps/volts to crank the engine but not enough to keep it running; to me the problem lies elsewhere...
someone please expain it to me...
Bill
Old 06-09-2012, 07:46 PM
Frankie the Fink
Frankie the Fink's Avatar
Received 7,082 Likes on 4,736 Posts
Army
Had two of those green '**** jobs'; both failed and now both of my classic cars have the knife switch...
To No good low down dirty rotton battery disconnects
Old 06-09-2012, 07:57 PM
jdk971
jdk971's Avatar
don't worry frank, will fall off in ten days. jim
Old 06-09-2012, 08:56 PM
ejboyd5
ejboyd5's Avatar
Just the basic Hella switch with the removable red handle. Easy to mount in the transmission tunnel, easy to reach from the driver's seat and actually very difficult to see unless you are looking for it. It has worked perfectly for me for many years.
Old 06-09-2012, 09:03 PM
Ron Miller
Ron Miller's Avatar
Plasticman
My experience as well . . . . .
Quick Reply: No good low down dirty rotton battery disconnects
