Cracking open 50 year old brass brake lines
Anyone have a special recipe? Ive rounded one off, using a brake line wrench....dont want to ruin another......
Help?!
D
Help?!
D
Heat? Warm fitting with heat gun?
Received 6,513 Likes
C2 of Year Finalist (track prepared) 2019
Thats a great tip, but there are no brass brake lines on any Corvette that I know of, and if they are in fact brass, they need changing anyway. There are some brass block fittings, but no lines.
Dhaaa, It was not specific to brass, But to any line fitting. Works especially well on heavily rusted lines.
I stripped my old donor frame today, my tubing wrench rounded the corners of the brake fittings but the vise grip trick tapped with a rubber hammer while applying pressure never failed. I wish I had read the tip to clamp the tubing wrench, could have saved some corners. Duh. Oh Well, next time.
Received 1,843 Likes
I use heat on the fittings. If I didn't have the acetylene torch, the vise grips on the flare wrench are a good idea too.
The flare nut usually seizes to the flare on the line and when you try to turn the nut, it tries to twist the line. The heat breaks that loose.
I purchased one awhile back just for this job. A bit of Kroil on the fittings and brake lines a day before removal also helps.
Larry
This style of vise-grip is supposed to work like a champ on brake line nuts.
Kind of combines to 2-wrench approach into a single tool.
Comes in 3 sizes -- the smallest is the best fit. I recently bought one but haven't had the "opportunity" to use it on a stubborn fitting yet.
Received 1,421 Likes
C1 of Year Finalist (stock) 2019
2018 C1 of Year Finalist
soak with Kroil
you can cut the line close to the fitting and use a 6 point socket to get the fitting loose from the block or whatever it leads into
lines can be cut by hand with side cuts
PB or Penetration Blaster works well. some company also makes some stuff with "freeze" in the name that is supposed to be quite effective for very rusted stuff, it breaks the bond and then the penetrating oil gets in there. If you end up replacing the caliper and line...which might not be bad idea on something that old...you maybe won't need to be so gentle just cut the line and remove the caliper/cylinder.
I used a super penetrant called Rust Buster by LA-CO...woked pretty good in most cases but I too rounded some off. Soon came to the realization that it was really time to replace all the 50+ year old lines so I bit the bullet... was a relatively easy job and now I rest easy...
This is what I do. Even high quality brake line wrenchs will start to spread when you start torquing on the fitting. Liberally spray the fitting with penetrating oil, use a good quality brake line wrench and clamp it down tight with vice grips.
