1963 LSx Project
#242
Thanks guys!!!
Yup, Stainless Works mufflers - Paul and the team have been great with both exhaust items and a multitude of custom stainless brackets I draw up and supply CAD files for to have the guys laser cut out...
I've got the extensions tack welded, shown here with the mock-up positioning clamps still holding things temporarily tight - I will be finish welding them up this week, along with the v-rings on the mufflers. Next is putting the pipes back on and tack welding the v-rings on the pipe side for perfect positioning of everything, then it's rear hanger design for the mufflers and mocking up some tips...
Also shown in the picture is a rough paper mock-up of a heat shield mentioned in the last post..
Have a great weekend!
Rich
Rich
#246
Hello Everyone,
Pipes welded and v-clamp ends on the pipes and mufflers...
Got everything in and installed, but just hanging in the rear with wire right now - need to design some hangers, tail pipes and also that heat shield under the fuel filter/regulator...
Have a great week!
Rich
Have a great week!
Rich
#248
Hello Everyone,
Last Saturday was amazing weather so I decided it was a good time to bring it back home...
In person, it just looked awesome at this angle, but the picture didn't capture everything in the same way...
I got the rear exhaust hangers and tailpipes all mocked up: Manufactured stainless pins, threaded at each end, they fit inside the frame channel and hang a poly style isolation hanger. Bent up some stainless rod for attachment hangers and used some pipe to mock-up what I need for tailpipes. The finished bent pipes will be on the way shortly and I can finish everything for good.
I'm really itching to start it to see what it sounds like, but I have to wait until I get the pipes and everything finished for good - tie wraps and plastic wire probably wouldn't last long - haa haa
Happy Easter Everyone!!!
Rich
Rich
#251
Car looks awesome, just looking at the pic of the front view.The front lower control arms look like they are pointing up at an angle.What kind of ride height are you running?When you ordered the chassis are you given the specs for ride height?
#252
Thanks Everyone
That picture is a little misleading, but it is sitting a little low, I haven't touched the height since I dropped the bare body on the frame, so all the weight has been settling things down, I need to go back and adjust everything. There is a general setting for what the free state of the shock should be from end to end and, I believe, the lower arms are best level..
Happy Easter!!!
Rich
Happy Easter!!!
Rich
#253
Hello Everyone,
Exhaust is pretty much done - I might add and/or make a double wall type of tip, but at the same time I'm really not trying to make the tips stand out as much as I'm trying to have them blend in - for that reason, I'm keeping them much shorter than original...
Turns out I don't need a heat shield for the fuel filter - it doesn't change temperature at all, I worry a shield would actually reduce airflow around it and make it get warmer...
Since it's in the garage, the sound isn't as clear as it is outside, I'll do that sometime later, but here is a clip.. Remember, it's an LS3, with a pretty large Texas Speed cam and ported heads, custom full length Stainless Works headers and full 3" pipes back to Stainless Works 3" chambered turbo mufflers...
I really like the sound, really mean idle, smooths out at steady state 2,000 and 3,000 rpms (those are the steps I hold it to in the clip) and, depending on how quick you let off, some gurgling on the way back to idle - for those that don't like that, it can be tuned out to a degree...
https://www.youtube.com/watch?v=Ujl3...ature=youtu.be
Rich
Rich
#257
Hello Everyone,
Got to work on modifying the rear panel for the larger pipes. I filled the original openings in with West Systems epoxy, cut new rough openings and then traced the pipes to get the correct oval again. Once I got the correct oval cut I used some heavy paper for a guide and created a flange with more epoxy. I'm not certain, at this time, if I'll make some stainless bezels or not, with the flanges painted perfect along with the rear panel things might look pretty nice without bezels..
Additionally, I hadn't yet installed all the deck lid latch/lock hardware, so I took care of that this weekend.. Nothing exciting to show in pictures with that other than I carefully cut the carpet in such a way to make the latch catch pieces "appear" through the carpet - I like this picture because in the ledge of the deck opening you can see a clear reflection of the camera and my arm - and it was covered in dust...
Have a great week!
Rich
Have a great week!
Rich
#258
Hello Everyone,
I haven't loaded pictures from the camera, but the rear panel is off to paint and I've been working on the console trim and heater side panels - I'll get pictures of everything as I progress more..
However, although it's just with the I-phone, here is an clip of it running outside..
https://www.youtube.com/watch?v=NCZJ...ature=youtu.be
Yes, first time out under it's own power - although I was sitting on the floor!
I peak, looking back, in the video, because when I did sound clips without the mufflers I'd always knock the camera/phone over with the first rev of the engine - looks like the mufflers solved that problem..
In person, it sounds really amazing!
Have a great week!
Rich
Have a great week!
Rich
#260
Those mufflers have a very aggressive raspy idle, but smooth out and have a newer performance sound under acceleration, which was not what i was expecting. I like it and believe i will copy your choice of muffler!
