61-Need header help for 383 stroker/350 blk
OK what is a good fittin' header on a 61 frame with a 350 small block. can't seem to find any definite ansers and dont want to strt shipping stuff in from everywhere. Thank you gurus
I had no issues installing my Hooker Supercomps other than playing with the clocking of my starter for while till it cleared. I have a 153 tooth flywheel and a McLeod scattershield so I don't know how they would work with the stock bellhousing and starter.
Doug's was my second choice. Are you looking for long tube or shorties?
DT
DT
Hedmann if you have angle plug heads, Hooker super comps if you have straight plug heads, or want to take a chance they will work with your particular angle plug head.
Doug
Doug
Long tubes. If I had a low rpm torque motor, I think I'd run 2.5" cast iron Tru-Rams.
http://www.castheads.com/corvette_systems.php
DT
DT
