Lock mechanism between the seats
Received 1,859 Likes
I'd just add that when you re-insert the key cylinder in the housing, DON'T install the cylinder upside-down; you won't have a hole in the bottom of the housing to access the little spring-loaded retainer plate, and you won't be able to remove the cylinder again.
