C2 front clip bonding, PT 2
1 Post
I use 3M 8115, just remember Do Not Over Clamp you will weaken the bond. Also prefit prefit use lineup marks and have help.keep in mind your working time for the adhesive along with the ambient temp that will effect your cure time.If you do the prefit along with lineup marks it should go fine. One extra note when you have the panels prefit you don't want them to be stressed,they should lineup without force. Good luck
