Go Back   Corvette Forum > C1 & C2 Corvettes, 1953 - 1967 > C1 & C2 Corvettes
Register Forgot Password?
Register Search Today's Posts Mark Forums Read FAQ Vendor Directory
Search
C1 & C2 Corvettes
General C1 Corvette & C2 Corvette Discussion, Technical Info, Performance Upgrades, Project Builds, Restorations Sponsored by
Flaming River
Industries
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C7 Parts & Accessories
C6 Parts & Accessories
C5 Parts & Accessories
C4 Parts & Accessories
C3 Parts & Accessories
C2 Parts & Accessories
C1 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 02-19-2012, 07:32 PM   #1
plaidside
CF Senior Member
plaidside's Avatar
Default Pilot bearing vs bushing
I went over a friendís house today to install his flywheel and remove and install the pilot bushing.
This is what I removed from his crank. Lucky for him it did not tear up his input shaft.
This is why I only use a bronze bushing!
Joe
Click the image to open in full size.
plaidside is offline   Reply With Quote
Old 02-19-2012, 07:43 PM   #2
1snake
CF Senior Member
1snake's Avatar
Can't argue with that picture. I've never used a roller bearing and never will. I see no advantage to them. Only dis-advantages.
Jim
1snake is offline   Reply With Quote
Old 02-19-2012, 07:47 PM   #3
MikeM
CF Senior Member
When in doubt, do as the engineers did. They knew about pilot rollers when the C-2 was designed. They also knew, the C-2 design was a little too loose to use something as precise as the needle roller!
Nothing wrong with the right bushing!
MikeM is offline   Reply With Quote
Old 02-19-2012, 07:58 PM   #4
Mike Geary
CF Senior Member
Mike Geary's Avatar
When hammering in a pilot bushing, what can you do to minimize the abuse to the thrust bearing surfaces? (other than freezing the bushing)
Or is there nothing to worry about -- just flail away?
Mike Geary is offline   Reply With Quote
Old 02-19-2012, 08:17 PM   #5
plaidside
CF Senior Member
plaidside's Avatar
"thrust bearing surfaces"
Do you mean the face of the bushing facing you when installed?
I use a bushing driver the same OD as the bushing, never drive it in with just a hammer, and drive it in until it is flush with the crank. Never had any issues. Always install the bushing with the concave center facing outward.
Joe
Old 02-19-2012, 08:33 PM   #6
Mike Geary
CF Senior Member
Mike Geary's Avatar
Joe
Joe:
I'm worrying about the rear crank main bearing, the one with the flanges (thrust?).
Seems like the flange surfaces would take the brunt of the hammering. So I was wondering if there's some trick to block the crank's flywheel mounting flange while you beat the pilot bushing into place.
Mike
Old 02-19-2012, 08:46 PM   #7
plaidside
CF Senior Member
plaidside's Avatar
Joe:
Mike
I wouldn't worry about the thrust surface as long as you are not using a 5lb. lump hammer!
Back when GM did not use a bolt to hold the balancer on the accepted method of installing the balancer was to drive it on with a block of wood and a large hammer. I must have done hundreds that way and never had anyone come back with a bearing problem.
Joe
Old 02-19-2012, 08:48 PM   #8
Pilot Dan
CF Senior Member
Pilot Dan's Avatar
Joe, that picture speaks volumes. I only use the solid bronze bearings, never had any problems ever with those.
Pilot Dan is offline   Reply With Quote
Old 02-19-2012, 10:09 PM   #9
65tripleblack
CF Senior Member
65tripleblack's Avatar
i went over a friend’s house today to install his flywheel and remove and install the pilot bushing.
This is what i removed from his crank. Lucky for him it did not tear up his input shaft.
This is why i only use a bronze bushing!
Joe
tko?
65tripleblack is offline   Reply With Quote
Old 02-19-2012, 10:54 PM   #10
Vet65te
CF Senior Member
Vet65te's Avatar
Default Sure Looks Familiar
When I rebuilt the L79 from my 66 Coupe in '94, I read that GM had a 'better version' of the aftermarket roller needle pilot bearing. Something like 17 or so rollers instead of the 12 the aftermarket versions came with. Hey, must be a good way to go sooooo, I picked up a few. Since '94 I've only put about 5K miles on that engine but started to notice an odd thing happening about a half dozen years ago. After putting the shifter into first I had my hand off the shifter and was slowing letting the clutch out, as you'd do in traffic or in this case, moving up the staging line at Infineon Raceway at the Wednesday Night Drags. Well, as the clutch started to engage, I heard this strange 'rattle' and felt a vibration and on occasion, the shifter would try to kick back out of first gear. All this was happening with the car barely moving. The work-around was to keep my hand on the shifter but last year when the speedo stopped working due to a slightly mis-aligned steel drive gear and the trans had to come out, the reason for the rattle and popping out of first gear showed itself. The new/unused GM roller pilot bearing is on the left and the disintegrated one on the right and debris out front is from my 66 Coupe after about 5K miles.
It now has a GM brass pilot bushing and no problems since.
Mike T.
Vet65te is online now   Reply With Quote
Old 02-19-2012, 11:08 PM   #11
Vette Daddy
CF Senior Member
Vette Daddy's Avatar
Joe
Vette Daddy is offline   Reply With Quote
Old 02-20-2012, 07:22 AM   #12
DansYellow66
CF Senior Member
DansYellow66's Avatar
Pretty substantial evidence to avoid roller pilot-shaft bearings. I tried one when I first reassembled my car and because I was having some transmission problems and had to remove it several times, I discovered I couldn't keep the bushing in the crankshaft - it was always loose. Finally gave up and went back to bronze before it could mess up.
Curious - Vet65te and Plaidside - did you both dial indicator check your bellhousings for radial runout as they suggest? My assumption is you probably did and it apparently makes no difference.
DansYellow66 is offline   Reply With Quote
Old 02-20-2012, 07:40 AM   #13
DZAUTO
CF Senior Member
I don't do social media stuff I Don't do it I Don't do it I Don't do it I Don't do it I Don't do it
And how many times in the past have I said that the above photos are why I do not and will not use the roller pilot bearing???????
Below is what can occur to the pilot of the input shaft when a roller bearing fails.
Tom Parsons
__________________
Tom Parsons
DZAUTO is offline   Reply With Quote
Old 02-20-2012, 07:47 AM   #14
plaidside
CF Senior Member
plaidside's Avatar
[QUOTE=Curious - Vet65te and Plaidside - did you both dial indicator check your bellhousings for radial runout as they suggest? My assumption is you probably did and it apparently makes no difference.[/QUOTE]
I took this out of my friends 69 Camaro. He had someone put an engine in his car over 15 years ago and he said they put in a new clutch at that time.
Funny thing, he had severe clutch chatter and a noise when the car was in neutral at idle that sounded like a bearing. It went away when he depressed the clutch.
From his description I thought it was a front transmission bearing. So while the trans was out he brought to me and when I disassembled it and I could not find the cause. I rebuilt it anyway just to be safe.
So I wonder if this bad pilot bearing could be the cause.
I will help him next weekend to install the transmission and see if his problems are solved.
I sell new clutch kits in my store and I notice they all now package only the needle pilot bearings. So I keep the bushings instock.
Joe
Old 02-20-2012, 08:09 AM   #15
Frankie the Fink
CF Senior Member
Support Corvetteforum!
Frankie the Fink's Avatar
Interesting - since Kiesler requires a needle bearing on their Tremec conversions to meet the warranty conditions. Luckily I haven't had any trouble so far or else I have and it hasn't manifested itself yet!
Frankie the Fink is offline   Reply With Quote
Old 02-20-2012, 08:31 AM   #16
wmf62
CF Senior Member
St. Jude Donor '07
wmf62's Avatar
Quote:
Frank
kind of reminds me of the computer scenario: it isn't a matter of 'if' a hard drive will fail, just 'when' it will fail...
Bill
wmf62 is offline   Reply With Quote
Old 02-20-2012, 08:33 AM   #17
DZAUTO
CF Senior Member
And that is absolutely correct.
Now, I must admit I have no personal experience with a Kiesler tranny, so I can't speak to the use of a bushing or bearing with it. BUT, I do have, and have had since 1988, a Richmond 5sp behind a 455 in the Cutlass ---------------------- WITH A PILOT BUSHING-------------- and zero problems.
So, if because of Kiesler's instructions to use only a bearing with their trannys, then the ONLY thing I can suggest to minimize the possibility of a bearing failure is to THOROUGHLY pack the rollers with grease.
Tom Parsons
__________________
Tom Parsons
Old 02-20-2012, 10:22 AM   #18
FlaVert
CF Senior Member
FlaVert's Avatar
I was always told, "Bushings wear, bearings FAIL."
FlaVert is offline   Reply With Quote
Old 02-20-2012, 12:09 PM   #19
4 Speed Dave
CF Senior Member
4 Speed Dave's Avatar
I have had a normal pilot bushing fail on my Nova Jerico application. Granted this is a highly abusive application but they still can fail. If someone is having problems with the pilot bushings I would highly suggest dialing in your bellhousing. Hardly anyone outside the racing enviroment does this but on all my stick cars I dial the bellhousing in so the input is in direct alignment with the center of the crankshaft, i.e. pilot bushing. If your transmission input shaft and the pilot bushing on the crankshaft are not in alignment the input will be in a slight bind and will wear out a roller bearing or bronze pilot bushing.
4 Speed Dave is offline   Reply With Quote
Old 02-20-2012, 12:27 PM   #20
MikeM
CF Senior Member
Reload this Page Pilot bearing vs bushing
Tags
bearing, bearings, bushing, c2, c4, corvette, crankshaft, forum, gm, install, pilot, removal, repair, sale, speed, squeaking, thrust
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
