Distributor Install
Distributor Install
I'll be attemtping to install the TI distributor on my 65 BB this week, would someone mind to give me a quick overview?
Car is at TDC - I know I'll need the rotor to point to # 1 cylinder - is that the one just to the right of center on the cap?
I had installed it approx. 6 months ago but I was way off.
2023 C1 of the Year Finalist - Modified
2022 C1 of the Year Finalist - Modified
2020 C1 of the Year Finalist - Modified
2019 C1 of Year Finalist (performance mods)
2018 C1 of Year Finalist
You're right so far. You may have to turn the oil pump shaft on the pump to line up with the drive gear on the distributor shaft. Use a long screwdriver to turn it. There's a slot in the gear that lines up with the pump shaft. You'll feel the distributor drop down on the shaft when it's lined up properly.
be sure you are not 180 out. turn the crank a little each way and the intake and exhaust on #6 should "rock" then you know that you are not 180 out and are on #1 or TDC, then simply point the rotor toward #1 spark plug wire. don't worry about the oil pump, bump the motor and it will fall in to place. obviously if you turn the crank a little each way and #1 valves rock you are 180 out, turn the crank one revolution, or simply set the distributor to #6. plain as mud?
Is there a sure fire way to confirm that I am at TDC with the valve covers on?
Hook up compression tester to #1 while I am turning engine by hand?
A old shade tree way was to put your finger OVER ( not in) the number 1 sparkplug hole while cranking. When you felt pressure or heard it "wosh", it was at, or near, #1. Your tester will do the same. By the way, with the marks aligned on the dampener and cam cover, it has to be on #1 or 180 out. A timming light helps too.
Lars document attached
In addition to the above points instead of using TDC on the damper a setting of 8-10 degrees BTC is better. When you have settled the distributor down on the cam gear turn the distributor to the trigger point. On a points trigger is when the points are just opening. Sorry I have never had a TI .
Do you know if your balancer mark correct?
Conversely, if you peek at one of these two springs and find that it's NOT open, it means that the other cylinder (1 or 6) is at TDC-firing.
Finally, if you don't have the luxury of having a oil fill cap at the front of either valve cover, it's still easier to remove a valve cover than to remove the #1 spark plug and then try to hold your finger over hole while cranking.
And, as Donald mentioned, set it to a few degrees (I like 12-15) before TDC as this is where the spark should occur.
Oh, and don't forget to put that spark plug back in place........
rustylugnuts
Even with all the excellent help I was unable to get it running last night, it would sputter a lot but not start.
Will have to reach out to a buddy today to see if he can come by this evening.
Probably best. Watch what your pal does closely (assuming he's good) and you'll see its really not that complicated once you have a 'walk-through' of the procedure...
I fought timing issues until we deterimined that the fuel was mostly water....LOL
