1963 Resto-mod has begun!
Old 02-23-2012, 04:30 PM
  #41
drnodegree
drnodegree's Avatar
Latest rendering.
I ended up choosing the Mast motorsports BLACK LABEL LS7 427 SS 675HP
Engine Should be ready in 4 weeks.
Tranny is still up in the air. 6 speed or the new Keisler 700 5 speed.
Should have this nailed down by the end of next week hopefully.
Old 02-23-2012, 05:14 PM
  #42
pw2006
pw2006's Avatar
Congrats! That is going to be sinister!
Old 02-23-2012, 05:37 PM
  #43
SLO 65
SLO 65's Avatar
Are the wheels factory 19x10 and 20x12? Planning on any body mods to fit the rubber?
Nick
Old 02-23-2012, 06:24 PM
  #44
drnodegree
drnodegree's Avatar
Nick
Yes they are that size.
The rear tires will not be a problem using Mini-tubs, the front tires may be more complicated.
We should know how much of a difference 1/2" on a front wheel makes. There are lots of C2's out there with the 19x9.5 factory wheels on them using this chassis or one similar (i have seen some with modifications made to fit them). I will know more next week.
Old 03-09-2012, 06:40 PM
  #45
drnodegree
drnodegree's Avatar
Default Tubs and wheels on.
Old 03-09-2012, 06:42 PM
  #46
drnodegree
drnodegree's Avatar
No problems with the front tire width...
Old 04-12-2012, 10:45 AM
  #47
drnodegree
drnodegree's Avatar
Old
Old 04-12-2012, 10:49 AM
  #48
drnodegree
drnodegree's Avatar
I was having difficulty deciding between flush mounting the glass or using the factory stainless (painted black) but tightening it up.
the flush glass option poses too many problems. The trim at the door/windshield is all stainless and with it removed there is oodles of work to do to the door.
I really didnt want it to look like a 64 that someone put the rear split onto it or that the car looked like a kit because too much of the originality was removed.
I have also decided to keep the factory door handles for this reason but am shaving them down/tightening them up similar to tucking in the bumpers.
Old 05-02-2012, 04:21 PM
  #49
drnodegree
drnodegree's Avatar
Default 9-10 weeks
Engine took WAY WAY longer than it should have...went from 4 week delivery to 10.
Tranny wasn't bad...but its all on track again.
Old 05-02-2012, 04:54 PM
  #50
XLR8OR
XLR8OR's Avatar
Default Engine Decision
I have used GM Crate Engines, built my own engines, purchased from engine builders like MTI Racing. If you are going to drive the car any distance, you may want to consider a GM crate engine because of warranty considerations. If your engine has problems a good distance from home and you have a GM crate engine, you're covered by the GM nationwide warranty - any GM dealer will service the car.
Old 06-12-2012, 08:18 PM
  #51
drnodegree
drnodegree's Avatar
Progress has been slow but steady.
Some Glass needed to be repaired behind the nose where some mounts were and the process of routing wiring and hoses is ongoing.
Fabrication of the side exhaust has begun and the side vents are cut out.
There is a cover that fits in over the wiper motor to hide it.
Old 06-12-2012, 09:23 PM
  #52
uxojerry
Support Corvetteforum!
uxojerry's Avatar
Beautiful build!! Have you considered posting your build on lateral-g.net or pro-touring.com? Our Corvette forum has some nice builds. It would be nice to post them on the other forums to show the young, how vintage Corvettes look when updated.
Old 06-12-2012, 10:14 PM
  #53
americanretrodave
americanretrodave's Avatar
It looks great and shows a tremendous amount of forethought; my hat’s off to you. What type of brake booster is that?
Old 06-14-2012, 07:11 PM
  #54
drnodegree
drnodegree's Avatar
Thanks, lots of dreams tied in with that forethought!
Its HYDRATECH
http://www.hydratechbraking.com/
Power steering pump "hydroboost" system.
Old 07-10-2012, 02:30 PM
  #55
drnodegree
drnodegree's Avatar
Bumpers are tucked.
Before:
After:
Old 07-10-2012, 02:34 PM
  #56
americanretrodave
Nice!!!!
Old 07-10-2012, 04:36 PM
  #57
TheSaint
TheSaint's Avatar
Do you have a pictures of the rear bumper brackets before and after they are tucked?
To 1963 Resto-mod has begun!
Old 07-25-2012, 06:05 PM
  #58
drnodegree
drnodegree's Avatar
Routing exhaust for side exit.
(sorry, forgot to take photos of the brackets)
Old 07-26-2012, 09:43 AM
  #59
OldKarz
OldKarz's Avatar
Location: On the bank of the Columbia River..... Washington State
Sweeeeet build!
Old 08-09-2012, 06:08 PM
  #60
drnodegree
drnodegree's Avatar
Working on the intake.
Quick Reply: 1963 Resto-mod has begun!
