Tips on a 67 Temp. Guage
Old 05-09-2002, 07:02 PM
steinboy56
steinboy56's Avatar
Default Tips on a 67 Temp. Guage
My temperature guage in my 67 goes to about 130 degrees and stops. Is it possible that is an accurate reading? In what order should I start checking and replacing? Thanks.
Old 05-09-2002, 07:19 PM
Guest
Guest
Posts: n/a
Default Re: Tips on a 67 Temp. Guage (steinboy56)
Hi Mark,
I emailed you a gauge trouble shooting guide. See if it helps. It's pretty short, but has some good information.
David.
Old 05-10-2002, 12:34 AM
wombvette
wombvette's Avatar
Default Re: Tips on a 67 Temp. Guage (67gilmore)
Simple. Remove the wire to the sender.(green) Turn on the key. Look at the guage, it should deflect fully one way. Ground the wire and recheck the guage, it should deflect all the way to the other side. If this works it is the sender if not the wires or the guage.
Old 05-10-2002, 01:01 AM
62fuelie
62fuelie's Avatar
Default Re: Tips on a 67 Temp. Guage (wombvette)
Wombvette is right on the money. Ground the gauge sending wire momentarily to avoid possible damage. If you can lay hands on an IR thermometer, check the temp at the base of the thermostat housing. That should give you a reading within a few degrees of actual coolant temp. That will give you something to work with. In the case of a low reading, be sure the sender is not installed with teflon tape of pipe sealer which will insulate the sender body from ground. This will produce an artifical low reading.
To Tips on a 67 Temp. Guage
Quick Reply: Tips on a 67 Temp. Guage
