Speaker Grill Screen
I was wondering if there is a way to take this off from the top or is it secured from the bottom? Dont really understand how it is mounted and I need to get it off but can't really see anything from either side that helps.
Thanks - Brian
Thanks - Brian
the metal screen is held in by nuts on all 4 corners. They also hold the speaker in place. You can access them after removing the glove box liner.
1 Post
I replaced mine about a year ago. Based on what I read hear on the forum, I was expecting it to be a bear - wasn't bad at all (no AC).
Remove glove box (10-15 minutes), remove clock (2-3 min), 3 of the 4 nuts on the grille are easy to reach and remove, the 4th nut (driver side closer to windshield) takes a little more fitness. 1/4" drive ratchet, magnetic (magnet inserts) socket and 12" extension, and you on your back will do it.
Plan on doing a lot of dusting/cleaning after you remove the glove box...you'll see what I mean.
Good luck!
Good luck!
I can send you a photo of the underside, I have the dash out right now with the speaker and defroster vent bolted up. That will show you the bolt pattern.
64 w/AC
Let me know
Jim
64 w/AC
Let me know
Jim
