Replacing grommet on '63 speedo cable
Old 12-06-2011, 02:29 PM
63atlast
63atlast's Avatar
Default Replacing grommet on '63 speedo cable
I am replacing the speedo cable and grommet on my '63. I thought the grommet would have a "split" in it so that it could be twisted on to the cable. Not true. The old grommet and the new one are both whole pieces. Must have to remove one of the speedo ends to replace the grommet, but neither seem to want to budge easily and I do not want to mess up the new cable.
Okay, guys, what's the secret here? Thanks for your help.
Roger
Old 12-06-2011, 03:01 PM
DZVette
Support Corvetteforum!
DZVette's Avatar
LIC and others sell a pointed tool that screws onto the cable and you slide the grommet over that.
37-16E TACH/SPEEDO CABLE GROMMET INSTALLATION TOOL 63-4 1
$6.50
http://www.parts123.com/parts123/yb....370a~~~Z5Z5Z51
You could probably rig something out of a wooden dowel.
DZ
Old 12-06-2011, 03:09 PM
63atlast
63atlast's Avatar
$6.50
DZ
DZ, thanks. Should have known that I would need "one more tool" for this job. Frankly, I've never seen one of these types of grommets that did not have a split in it. Never thought to look before I ordered it. Thanks again.
Roger
Old 12-06-2011, 03:30 PM
63atlast
63atlast's Avatar
Roger
DZ, appreciate the idea. The end of an old plastic funnel made a perfect tool. Slipped right on.
Roger
Old 12-06-2011, 04:01 PM
Too Slow '90
Too Slow '90's Avatar
Roger
Good for you. I split one last year trying to do the same thing. It was a BIOTCH to split and it did not fit when I was done. I probably should have asked the same question!
Old 12-06-2011, 04:09 PM
63atlast
63atlast's Avatar
Too slow...many, many times I've learned how to do it "right" by doing it wrong first. This is a great forum. Lots of good guys who, like me, have already done this stuff the hard way. I always appreciate the help that is available.
Roger
Old 12-06-2011, 04:37 PM
JohnZ
JohnZ's Avatar
Received 1,857 Likes on 1,100 Posts
In the plant, we used an aluminum version of the home-made wooden tool in the photo below, with a little 50-50 solution of Joy soap and water; worked slick.
Old 12-06-2011, 04:59 PM
63atlast
63atlast's Avatar
JohnZ...it's always great to know how the experts did it. Thanks for the reply and the picture. My old plastic funnel neck worked for me, but my "tool" was not nearly as professional looking as yours. I also didn't think about putting the string through it to hold it in place. I needed three hands...one to hold it and two to pull it on. Roger
Old 12-07-2011, 01:28 PM
DZVette
DZVette's Avatar
Roger
Glad you got this worked out. Your funnel solution was creative!
Dave Z
To Replacing grommet on '63 speedo cable
Quick Reply: Replacing grommet on '63 speedo cable
