64 Diff. Code?
Received 1,857 Likes
The Julian date code (3 3 4) pretty much confirms that it's a '78 or '79 3.55 Posi ("OH") axle, made on the 334th day of the year. The casting date will be on the driver's side, partially hidden by the front of the strut rod bracket.
Yup - the 464910 rear cover was used in '78-'79, with the 7/16" rear spring retainer plate bolts (vs. the 1/2" bolts used from '63-'77) to accommodate the '78-up 2-1/4"-wide spring.
JohnZ,
As you stated in an earlier post, there is a P-code on the side of the muncie 4-speed in my car.
It is: P8T18
If I understand it correctly that means it was built on December 18th,
1967 , for a 1968 car.
Still not sure if it is a M20, M21 or M22.
It is: P8T18
That's correct. Pulling the side cover and looking at the helix angle of the gears is the sure-fire way to tell, but it's highly unlikely that it's an M22. If the rpm drop from 3-4 is the same as it is from 1-2 and 2-3, it's an M21; if the rpm drop from 3-4 is much greater than it is from 1-2 and 2-3, it's an M20.
