63 AM/FM radio repair question
The AM/FM radio in my '63 makes a loud scratching sound when powering on or adjusting the volume ****. Can anyone suggest a repair service?
Also, does the glove box need to come out in order to remove the radio?
TIA
TIA
Platinum Supporting Dealership
Todds Electronics in MO always have an ad in the NCRS Driveline. Been doing repairs for over 50 years on Delco radios.
314-277-9333 or 636-926-2267
__________________
Tom Hendricks tom@budschevy.com
Corvette Specialist Since 1993
BUDS CHEVROLET
St. Marys, Ohio
800-688-2837
WEBSITE WWW.BUDSCHEVY.COM
HOURS MON-WED 7:00AM - 5:00PM
FFRIDAY AND SATURDAY BY APPT.
OFF THURSDAYS
NCRS # 23758 Miami Valley Chapter ( Ohio )
NCM Founding Member #1143
NADA Classic Car Guide Advisiory Board Member
C5/C6 Registry Corporate Member # 5
My Corvettes. 63, 71, 73, 78.
Facebook Post
BUDS CHEVROLET
St. Marys, Ohio
800-688-2837
OFF THURSDAYS
No you do not need to remove the glove box. Just the 2 radio side panels. For some reason the radio seems to come out the drivers side easier or at least it's that way for me
Received 6,547 Likes
C2 of Year Finalist (track prepared) 2019
You might have to remove the radio to gain physical access to the volume control, but you can almost certainly save the cost of a repair bill if you will do this yourself.
Jim
It's caused by dust or corrosion on the wiper of the volume control. It has an opening just behind where the wires attach to the volume portion of the control. Spray some contact or tuner cleaner into that opening and move the volume up and down rapidly to clean the contacts. You can also disconnect the battery and run the volume up and down multiple times and get it much quieter, but not as good as using cleaner. A little spray will do you.
You saved me about $200! Where do I send your commission? :o
To my surprise, turning on and off plus running the volume up and down multiple times was a quick fix! I will take the time at a later date (good rainy Saturday project) to pull the radio and spray contact cleaner on the wiper area.
1 Post
Roger
Glad you got it working. If you ever do need a radio repair there is a guy in Chattanooga, TN that I have used a couple of times. Does excellent work, reasonably quick turn around, reasonable prices. He has the AM/FM out of my '63 right now. Gene Edwards (423) 877-9910. Good luck.
Roger
Roger
Thanks for the info. From the phone number, sounds like Gene is in the Hixson area...I'm originally from Chattanooga and visit often (now in Mt. Juliet).
Dennis
radio noise (volume control)
I have posted good results solving problem on my 63 swc with am radio. Volume control noIsy on opening radio, volume increases, etc. Pull off the volume shaft ****.Turn on radio, with a small hammer, give the end of the volume shaft a sharp rap . This caused control to work properly. Probably a poor ground.NO RESPONSIBILITY ON MY PART ! Confirmed works by several members. Regards, Abe G
