Holley carb help needed
I'd like to get the choke working again on my Holley 4150. When the throttle is fully opened, the fast idle cam is not being pushed far enough to engage. I didnt see anything that can be adjusted to push it just a hair further?? New cam? Thanks!
I don't have a choke on mine but here is a PDF I found on the subject.
http://www.holley.com/data/Products/...199R7948-5.pdf
some models you can use a screwdriver to bend the tang that engages the fast idle cam
your question is really too vague to cover all the choke assy's...hope this helps
you may need to richen the spring if you have that type
If so then what did you do to make it stop working ?
Fast idle cam should be rotated into correct position by the choke spring.
Re "new cam ?" - probably new choke spring thermostat is what you need.
I didnt know the choke spring would adjust the position of the cam? I thought the spring adjustment determined when the choke turns on and off?
Received 1,857 Likes
Which carb is it - a 2818?
Forgive my ignorance on the carb. I didnt play with the choke spring adjustment. I just noticed that when I fully open the throttle, it didnt push the fast idle cam enough to engage it.
Full throttle actually disengages the fast idle cam - you've got it a$$ backwards
"Play with it" (hold the throttle partially open and move the choke spring) and observe - it's not very hard to figure out.
Again forgive my lack of knowledge on this subject but here is what I have: Engine is cold and the choke plate is fully closed. If throttle is fully opened the choke plate begins to open but fully closes upon release of the throttle. If I push down on the fast idle cam the choke plate "clicks" slightly open and remains open and the car will start fine and idle fast until I tap the throttle.
I tried adjusting the spring as recommended above with no luck. When the throttle is fully opened is the choke plate supposed to be pushed open and remain engaged barely open or should the choke plate "fall" open? Hard to explain but maybe someone can help.
With everything stone cold ;
you push the throttle down SLIGHTLY and the choke should close and the the choke side throttle linkage should rest on the fast idle cam.
If you fully open the throttle the choke should open slightly - 1/8" or so.
With engine warmed up;
If you fully open the throttle the choke should fall open.
With motor cold : what happens to the motor operation when you pump the gas a couple of times and start the car : Does it start okay and run on fast idle until you open the throttle and then it goes back to regular idle ?
AND does the choke gradually open up - watching it for 3-4 minutes or so ?
Jerry
when you open up the throttle all the way, the choke will unload a fraction of an inch
so, when you depress the pedal say half way, the choke should slam shut and activate the fast idle cam and adjustment, only on a cold mill.....hope this helps
If I pump the throttle a couple times the car starts fine but I have to hold the RPM up until warm. Its a convenience factor to get the choke working.
When the engine is cold, should the choke plate be completely closed with the throttle closed? Right now its completely closed when cold.
on a cold engine, when you slightly tap the throttle, the choke should close tightly
Or does it just slow down quickly and die ?
Okay now we are starting to get somewhere ! Some actual operational observation !
Check and confirm what is happening with the choke blade when this happens - sounds like the choke is falling open / opening to quickly.
If that is the case (choke falling open) you need to wind the choke adjustment (black cap) tighter to hold the choke closed with more spring pressure.
65 dude probably has a valid point regarding fuel bowls being empty.
Yes 65 dude the choke can not and does not close on it's own until you "release it" by opening the throttle.
you may want to get into the choke housing and check the piston pull off for crud or a bad spring...just a thought
1. When the engine is cold, should the choke plate be fully closed? (mine is)
2. Then by fully depressing the throttle, the choke plate should slightly open (and stay slightly opened) right? ready to start and fast idle until warm or tapping the throttle? (mine doesnt)
thanks again for the help...
