Corvette Forum
Go Back   Corvette Forum > C1 & C2 Corvettes, 1953 - 1967 > C1 & C2 Corvettes
Register Forgot Password?
Register Vendors Buy a Vette Albums Search Today's Posts Mark Forums Read FAQ TSB & RecallsGarage
Search
C1 & C2 Corvettes
General C1 Corvette & C2 Corvette Discussion, Technical Info, Performance Upgrades, Project Builds, Restorations Sponsored by
Flaming River
Industries
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 10-22-2011, 04:23 PM   #1
lucky131969
lucky131969's Avatar
Send a message via Yahoo to lucky131969
Default L76 - 326 water pump
I'm on my second reproduction 326 water pump(in 6 months). The first one leaked from the back cover, and the second one failed today (shaft walked back, pulley started grinding the pump casting.......less than 300 miles on the pump).
I'll preface my question by stating, the belts were not too tight (is an A/C car).
I want to put a new pump on this engine, and be done with it. That being said, I either want a quality 326 pump......or ......a brand new pump that will fit properly, taking into account the unique pulley (L76 with A/C),provisions for the compressor brackets, bypass, etc. This is not an NCRS car, so if I can pick up a quality aftermarket pump, that is dimensionally the same as the 326, I'm all for it.
Thanks in advance....
lucky131969 is offline   Reply With Quote
Old 10-22-2011, 05:26 PM   #2
65 vette dude
CF Senior Member
65 vette dude's Avatar
Send your pump to Arthur Gould, or you can buy one from him. He uses only the best parts, and he rebuilds them to last.........http://arthurgouldrebuilders.com/about/
65 vette dude is offline   Reply With Quote
Old 10-22-2011, 06:18 PM   #3
65tripleblack
CF Senior Member
65tripleblack's Avatar
The leaky back cover could have been sealed easily by straightening the cover and using a new gasket with Permatex or equivalent on both sides. I had the same happen and I used black RTV. Torqued the bolts to 8 ft-lbs metal-to-metal. No leaks now and never will be.
If the pump has been rebuilt more than a few times, then the bearing bore will not hold the bearing as well as a new one. This has also happened to me where the bearing walked forward and started leaking on a brand new pump. The rebuilder (Stewart Pumps)
http://www.stewartcomponents.com/
Rebuilt it a second time, for free, but sent back a note in the box saying that the pump could be reasonably relied upon to perform trouble free at speeds under 7000 RPM, but speeds above were at my own risk.
Stewart pumps use only genuine FAG, American Made bearings. They provide services to many NASCAR teams, among others.
If you drive your car regularly, and subject it to severe duty from time-to-time, then you're much better off installing a new OTC pump. The bypass hose is not necessary and won't be missed.
65tripleblack is offline   Reply With Quote
Old 10-22-2011, 08:22 PM   #4
lucky131969
Quote:
Thanks.
Old 10-22-2011, 08:24 PM   #5
lucky131969
I tried sealing the first pump...even let the RTV set up for 48 hours before installing....it still leaked.
I'll check out Stewart. I might explore 6k RPM once in a while, but that's it.
Old 10-24-2011, 11:34 AM   #6
Ironcross
CF Senior Member
Ironcross's Avatar
gentlemen, I could never see the benifit of a rebuilt water pump when new is probably just around the corner at a reliable new parts store......Airtex is a brand name sold at many parts stores....
Ironcross is offline   Reply With Quote
Old 10-24-2011, 01:22 PM   #7
lucky131969
Quote:
Do you have an L76 or L79?
Old 10-24-2011, 05:36 PM   #8
Ironcross
CF Senior Member
Ironcross's Avatar
No, whats the difference, there both small block Chevys and all Vettes use the short pump
Old 10-24-2011, 06:50 PM   #9
larrywalk
CF Senior Member
larrywalk's Avatar
Not all SBC short water pumps are the same in C2 and C3 corvettes! Up to about 1969 or 1970, the pump shaft diameter was 5/8", but after this time, the Corvette short water pump got a stronger 3/4" shaft making pulley and viscous fan clutch interchangeability problematic. Further, the later pump with the 3/4" shaft locates the flange for the pulley about .150" farther from the block, so it is not as short as the "short" SBC water pump.
Guess why so many complain about belt alignment problems!
larrywalk is offline   Reply With Quote
Old 10-24-2011, 08:20 PM   #10
lucky131969
A few things are unique, that make finding an aftermarket (or reproduction a chore). I have an L76 with A/C, which means the pulley is unique(not to mention a bastard to find). The clearance between the back edge of the pulley and the water pump is very tight.....so if the hub is pressed on too far, it's an issue. Not all aftermarket pump cover bolts will clear my timing cover. I also want the correct provisions for the bypass, without using an adapter. I found a professional builder in the NCRS Driveline, that has an original GM1 casting 326, and guarantees his pumps for life. Yes, more pricey than the repros, but I'm done rolling the dice with this Chinese crap.
Old 10-25-2011, 02:11 PM   #11
JohnZ
CF Senior Member
Support Corvetteforum!
Quote:
The change in the bearing/shaft/pilot size and hub bolt pattern occurred for the 1971 model year on both SB and BB pumps.
JohnZ is offline   Reply With Quote
Reload this Page L76 - 326 water pump
Tags
1964, 1967, 326, alum, corvette, diameter, engine, fan, hub, l76, lookup, pump, pumps, shaft, size, water
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.2
Emails & Password Backup
