'62 Turn Signals
'62 Turn Signals
Okay... I cannot figure this one out... let me start with... I put in new turn signal wiring extensions like these...
Now... when I turn on the parking lamps they have the same intensity... and the left turn signal flashes brighter when activated... but the right one will not flash at all... I put in new bulbs... and have swapped wires... the bulbs are good...
1. Can someone confirm that the purple wire goes on top of connection to wiring harness? Blue and black wires on the bottom?
2. Thoughts on why the right side will not flash?
Thanks!
Thanks!
Not sure how this can be a problem....the wires are completely color matched...your extension wires entering the connector should match the wires exiting the connector to the main harness.
Be sure that you haven't inadvertently forced one of the bulbs into the socket the wrong way, can be done if the tolerances are sloppy between the bulbs and sockets.
Also be sure that all of the rear bulbs and connections are good.
Paul
Paul
