Radiator Cap
Old 09-26-2011, 01:34 PM
PY60Corvette
PY60Corvette's Avatar
Default Radiator Cap
1960, looks to be original radiator but appears to have been re-cored and using normal 7# cap. Just wondering if anyone has experimented using I believe what was the next step up in 1961 to a 13# cap. It seems like a big jump and I'm not sure if there is a cap between 7 and 13 #'s that would fit.
After flushing radiator and putting in a hi-flow thermostat most of over heating problems have gone away on hot days (hi 80's lo 90's) but when engine turned off overflow tube releases coolant to the ground (as it should).
Trying not to use recovery tank or purchase new radiator. Is a 13# cap too big a leap or is there something out there in between that might work or do I just need to bite the bullet and get a new aluminum radiator ?
Thanks, Paul
Old 09-26-2011, 02:01 PM
Frankie the Fink
Frankie the Fink's Avatar
Received 7,082 Likes on 4,736 Posts
Army
I run a 13# cap on my '61 but I have an expansion tank....car runs cool with no "puking" of coolant..but I do have an aluminum radiator.
Old 09-26-2011, 02:11 PM
wmf62
wmf62's Avatar
St. Jude Donor '07
try the cap.. a higher pressure cap just increases the boiling temperature of the coolant and minimizes the puking. just remember, the radiator will puke til the coolant reached equilibium with the expansion/contraction of the fluid. don't just keep adding as it will keep overflowing.
after a puking session, when the it's cool enough (but not sitting-overnight-cool) remove the cap and see where the coolant level is. then try it again the next morning; should be lower (but not down to the level of the radiator core).
keep checking over several days and see if the levels remain constant... if so, you're OK
Bill
Old 09-26-2011, 04:36 PM
C-1 Generation 2
C-1 Generation 2's Avatar
I used to use a 15# and now I'm using a 7#.I use an expansion tank and since installing a new DeWitts radiator a few years ago never have any puking.
Old 09-26-2011, 06:06 PM
0Tom@Dewitt
Former Vendor
Tom@Dewitt's Avatar
Originally Posted by wmf62
remove the cap and see where the coolant level is. then try it again the next morning; should be lower (but not down to the level of the radiator core). keep checking over several days and see if the levels remain constant... if so, you're OK
Bill
The curved filler neck on 55-60 radiators does not allow you to check the level and that's why this problem occurs. Since you can't see how much is in there, many tend to add more, and when it pushing it out, they add more.
Old 09-26-2011, 06:48 PM
62Jeff
Support Corvetteforum!
62Jeff's Avatar
How old is your heater core? Will an almost doubling of cooling system pressure risk the integrity of your heater core?
Old 09-26-2011, 07:16 PM
1snake
1snake's Avatar
Exactly. I've never run anything but 7 PSI caps. If your cooling system is in good shape, you won't have a problem. There's no need to add stress and increase the leak possibility by increasing the pressure. Going from a 7 lb. to a 15 lb. cap only raises the boiling point 17 degrees.
Jim
Old 09-26-2011, 10:26 PM
robert miller
robert miller's Avatar
Received 1,762 Likes on 1,529 Posts
Jim
Stay with the 7#...
Old 09-27-2011, 07:10 AM
Frankie the Fink
Army
No reason these systems shouldn't handle 13# of pressure or you obviously have other problems...here is an NOS cap you can pick up quickly for a test if you don't mind spending a LITTLE extra money for an original:
http://cgi.ebay.com/ebaymotors/1959-Corvette-FI-Fuel-Injection-New-AC-RC6-Radiator-Cap-?cmd=ViewItem&item=310119092681#vi-content
Old 09-27-2011, 07:49 AM
wmf62
wmf62's Avatar
St. Jude Donor '07
as Frank says, if your system is in good shape, the 13-15# cap will do no harm.
i just looked at where you live and i see it is up towards the Georgia mountains. if you do any driving into the appalachians, and it gets as hot as it did up there this summer, then a higher pressure cap will allow a bit more engine temperature while climbing some of the steep grades.
my .02..
Bill
Old 09-27-2011, 05:50 PM
Steve59
Steve59's Avatar
On my 59, I was running a 13# for years. Didn't know any better. Last year, blew a few holes in a 35 year old radiator. Actually found a guy who re-soldered the old original radiator ( the old ones apparently don't have "tubes", it's the small little fins that carry the coolant and are very difficult to solder). Went back to a 7# cap. No problems yet.
I also installed a 61 expansion tank. Was tired of having coolant all over the floor.
To Radiator Cap
Quick Reply: Radiator Cap
