How to Connect Dwell Tach Meter
Old 08-31-2011, 11:44 PM
54greg
Support Corvetteforum!
54greg's Avatar
Default How to Connect Dwell Tach Meter
My meter has 3 hookups. A red and black clips and a white clip.
Black to ground, red to negative coil and...........?
Old 08-31-2011, 11:49 PM
wombvette
wombvette's Avatar
Red to battery positive, black to ground and white to negative side of the coil.
Old 09-01-2011, 08:07 AM
66BlkBB
66BlkBB's Avatar
St. Jude Donor '13-'14-'15-'16-'17
Just a simple question and not trying to be a smart a$$. Why the white wire at all??? My tach/dwell meter only has the black and red leads. Works just fine and has for over 30 years. What is the white wire for?
Old 09-01-2011, 09:32 AM
wombvette
wombvette's Avatar
Every one that I have ever used has power leads and a signal. How else is it to read the RPM or the dwell.
Old 09-01-2011, 09:37 AM
Dave Tracy
Dave Tracy's Avatar
Mine has just 2 wires and will read the dwell and tach
Old 09-01-2011, 10:27 AM
MikeM
MikeM's Avatar
Received 1,843 Likes on 1,398 Posts
There are both two wire and three wire tach/dwell meters. I'm not sure but I think the two wire meters are later design circuitry and pick up their power off the ignition side of the coil.
Old 09-01-2011, 10:31 AM
Pilot Dan
Pilot Dan's Avatar
Exactly!
Old 09-01-2011, 11:11 AM
1snake
1snake's Avatar
I have two of them just like yours. Both are over 30 years old and still work perfectly. Never seen a 3 wire one. That would have me confused as well. I'd probably have to break out the instructions.
Jim
Old 09-01-2011, 11:17 AM
John BX NY
John BX NY's Avatar
It's good to have more than one dwell meter since sometimes they are inaccurate. I got my last one a Sun at a garage sale for $5....
wombvette
wombvette's Avatar
Jim
OK, so I haven't bought one in over 40 years. Haven't paid any attention to the new ones.
Old 09-01-2011, 11:24 AM
JohnZ
JohnZ's Avatar
Received 1,857 Likes on 1,100 Posts
I bought mine 45 years ago, and it has two wires - one to ground, the other to the coil (-); they don't make them like this any more - chrome die-cast housing, and glass lens on the meter.
Old 09-01-2011, 01:06 PM
plaidside
plaidside's Avatar
Received 1,126 Likes on 553 Posts
Some analog meters back then were multi-function, tach, dwell, volts and ohms. So you needed the extra lead to read battery volts or resistance.
Joe
Old 09-01-2011, 03:22 PM
wombvette
wombvette's Avatar
Joe
Yep, Thats the kind I have. You can check voltage and check point resistance.
Old 09-01-2011, 04:06 PM
MikeM
MikeM's Avatar
Well, I've learned something here. I have two meters. Both have two leads coming out of the handle. One of them is a tach/dwell meter and it works fine. The other is a "Milton 1212" brand meter and you can check point resistance and voltage. That is, if the meter would work and it doesn't.
Looking a little closer, it looks like there is a hole in the handle for another lead to come out and it's missing!
Never thought about this until now.
Old 09-01-2011, 09:29 PM
54greg
54greg's Avatar
Thanks all
Wombvette- thank you
To How to Connect Dwell Tach Meter
Quick Reply: How to Connect Dwell Tach Meter
