65 327/365 wont idle for more than a few minutes
I have just had the motor rebuilt, runs great, orig repop holley rebuilt, car starts great cold, warms up, and then cuts off and is hard to start. It spits gas out of the front vent tube before the stall.
Changed the needle and seats, put on an extra clear fuel filter to catch any debris. Still does it. When driving at speed car is fine--slowing down to stop--or idle it starts to stumble?????
Help---Fuel Pump??? Any Ideas?
Received 1,843 Likes
Drop your float level in the front bowl
POSSE ZR-1 Driver
Check your fuel pressure, Should be between 5-8psi if I remember correctly,
I have has past issues with today's fuel pumps having too much pressure. I went through 3 before I got one that wouldn't push the needle off the seat. One was pushing almost 15 psi.
The new material used for the diaphram is stiffer than the original and some springs have varying rates.
An engine operating in a perfectly normal temperature range can still percolate -- its the gasoline temp that's key not the water. However percolation doesn't seem to be the case here - Mike has it covered I think.
Ok--found out there was some small crap in the tank, replaced tank, sender and new rubber lines, new fuel pump. Dumped carb out, found tiny little metal particles in fuel. Blew out metal fuel line.
Hooked all back up---put about 4 gallons of new fuel in----NOW--no gas getting to carb---is there a special trick to draw the fuel all the way the first time??? Help!
If you don't have gas at the pump, add more gasoline or jack the back of the car up. But you shouldn't have to do that as the pump should pull it on through.
Thanks--no fuel at the pump--no fuel coming out at sender rubber hose either---I was think to hook up some type of vacum to the rubber hose at the carb to get the fuel through the system
You can stuff a rag around the fuel filler and stick pressureized air into the filler neck, that should get the fuel going the way you want but like I said, the pump should do that on it's own.
Even if you have this done properly there is a better than even chance that your 2818 will still flood when hot. It becomes most apparent after a highway run. The first time you come to a stop, the engine will cut out. Never was able to solve it completely with mine.
Received 1,720 Likes
2018 C1 of Year Finalist
