66 captive belt for L79
my 66 L79 is no air & no power steering. It uses the double row crank pulley and water pump pulley. One of the grooves is for the captive belt. The original GM part number is 3837810. The belt is also used on some of the big block cars as the captive belt.
Quanta make the correct reproduction belts, but there are two that reference the GM partg number 3837810. One is listed as Long and the other Short. I believe the lengths are 34.8" and 34.4".
My question is now do I determine which will fit my car? Since the belt goes between the water pump pulley and crank pulley there is not adjustment, so it must be tough to get on, and must be correct length.
When I got the car it had all the wrong pulleys and I am now replacing with correct pulleys and belts.
Thanks,
Don
Thanks,
Don
Received 2,127 Likes
Don,
I have never had this issue, but walking the belt on would be one process. Maybe you could leave the water pump pulley bolted, remove all but one bolt (loosen it) from the bottom pulley then pivot the pulley, slip the belt on, use a drift through one bolt hole to bring the pulley back in alignment and put the last two bolts in. JohnZ may know the actual process from the factory is different. Dennis
Thanks,
Don
Thanks,
Don
I just did mine on my 67 L79 and I bought both belts, the long one is to big and the shorter belt worked perfectly. It wasn't to bad to put on just takes a little time. Put the bolts in the pulley's but don't tighten down.
Mike
St. Jude Donor '07
Don,
Bill
Received 1,857 Likes
You won't be able to "walk the belt on" - either remove the fan clutch and water pump pulley to install it, or remove the crank pulley to install it. Photo below shows a '66 L-79 with no A/C or P/S on the line at St. Louis, and you can see the captive belt installed (the alternator went on later).
St. Jude Donor '07
i cut an old belt to see what fit and then measured the length and went to the local parts store and got that length and one a size longer and one a size shorter and went from there, then took the unused ones back.
you can use a piece of rope or string, but you will probably have to try more sizes.
Bill
Bill
