Go Back   Corvette Forum > C1 & C2 Corvettes, 1953 - 1967 > C1 & C2 Corvettes
Register Forgot Password?
Register Search Today's Posts Mark Forums Read FAQ Vendor Directory
Search
C1 & C2 Corvettes
General C1 Corvette & C2 Corvette Discussion, Technical Info, Performance Upgrades, Project Builds, Restorations Sponsored by
Flaming River
Industries
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C7 Parts & Accessories
C6 Parts & Accessories
C5 Parts & Accessories
C4 Parts & Accessories
C3 Parts & Accessories
C2 Parts & Accessories
C1 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 07-16-2011, 04:24 PM   #1
MFJ66VET
CF Member
Default Did my 1966 Corvette have a big block engine?
Can someone tell me how to identify what size of engine was originally placed in my car? I have this information behind the glove box:
Style 66 467 | A-651 Body
Trim 414 | 976 Paint
194676S120836
66
Thanks for your help.
MFJ66VET is offline   Reply With Quote
Old 07-16-2011, 04:27 PM   #2
magicv8
9 Hot Rod Power Tours
magicv8's Avatar
194676S120836
66
none of that helps - beyond the fact that it's a Stlouis car
all 66big blocks used an 11" clutch with a 14" diameter 168 tooth flywheel, EXCEPT L-88 (which used a 10.4" clutch with a 12-1/2" , 153 tooth flywheel). '444' (cast at top) clutch housing designed for use with a 14" flywheel. It was used for 1966 and very early 1967 Corvette with 427 (except L-88).
1965 block (cast) 3855962, heads 3856208
1966 block (cast) 3869942, heads (cast) 3872702, 3873858(425/450)
1967 block (cast) 3904351 after vin #173, heads 3909802, 3904391(435)
BB-SB DIFFERENCES:
80# oil (60# possible with 427/390)
5.5k redline tach 390 hp hydraulic lifters, 6.5k 425hp solid lifters
steel line from high limit oil pressure gage to engine.
front springs (tagged 3888250eb/std 3888251ef/c60 3832518ea/f41 )
front AND rear sway bar with 2 trailing arm holes drilled to mount the rear bar.
Fuel line engine supply ends with 90 bend 6 inches in front of the idle arm mount.
BB battery cables with riveted cable clip near RH (pass.) side of tunnel opening
BB and SB A-C cars have a LH battery holder and a washer bag
If 66-67, a brass GM radiator, plastic shroud
If 66-67, no aluminum expansion tank, mount holes filled from bottom
hood with intake port(s) and LH support after 65
all engine accessories except A-C compressor and PSpump
power steering pump hose and fitting
clutch cross shaft
lower splash shields have different exhaust cut outs
2.5 inch exhausts
exhaust heat shields
at, au, az, fa, fb, fc code stamped on differential
tapped differential yokes with bolt on caps
BB throttle lever curves back from pivot toward rear of car, SB is straight
TI box bolted for L79 on LH wheel well and its wiring clip under the master cylinder
If a 65, vin number higher than 13000
Registration weight shows BB added to the (327 with 3 speed) base car:
Convertible curb weight 3160
Coupe curb weight 3140
"add" weights:
a31 Power windows___ +5
co7 Hard top________+49
c48 less Heater______-20
c60 a-c____________+93
j50 power Brake_____ +12
L89 aluminum Heads__-73
m20 4speed _________-5
m35 powerglide ______+1
n40 power Steering__ +21
u69 radio __________ +21
l79 327/350 ________ -8
l36 427/390 ________+215
l68 427/400 ________+151
l71 427/435 ________+149
magicv8 is offline   Reply With Quote
Old 07-16-2011, 04:42 PM   #3
65GGvert
CF Senior Member
65GGvert's Avatar
Send a message via AIM to 65GGvert
BB-SB DIFFERENCES:
clutch cross shaft
2.5 inch exhausts
"add" weights:
Why do you say that is a St Louis car? Body A instead of S
65GGvert is online now   Reply With Quote
Old 07-16-2011, 05:41 PM   #4
Nowhere Man
CF Senior Member
Nowhere Man's Avatar
http://www.facebook.com/home.php?
Send a message via AIM to Nowhere Man
all that tells you is that you have a A.O. Smith built convertible body that is Nassau blue with bright blue interior. that was also built appr May 3, 1966
Nowhere Man is offline   Reply With Quote
Old 07-16-2011, 06:36 PM   #5
65GGvert
CF Senior Member
65GGvert's Avatar
Quote:
That's more like it.
Old 07-17-2011, 02:04 AM   #6
jkuzzy
CF Senior Member
jkuzzy's Avatar
My birthday! OK, I want to buy it!
jkuzzy is offline   Reply With Quote
Old 09-01-2011, 02:46 PM   #7
65 vette dude
CF Senior Member
65 vette dude's Avatar
Take a flashlight, and look on the back of the cluster. If your car was a big block, it should have a sticker with the letters LB on it. Of course that only helps if you still have the original cluster.
65 vette dude is offline   Reply With Quote
Old 09-01-2011, 02:50 PM   #8
midyear
CF Senior Member
midyear's Avatar
194676S120836
66
did you leave any numbers out?? because A-651 is for a car much earlier then your may vin number...indicates a possible vin/trim tag swap. and you should have a date on the trim tag in the upper left corner. a closer match would be a 102 vin instead of 120.
midyear is offline   Reply With Quote
Old 09-01-2011, 07:16 PM   #9
a66bbvet
CF Senior Member
a66bbvet's Avatar
I was not going to say anthing about the "BB-SB differences" list that was generated a few day ago as while not completely correct it was a very good starting list. But if this list is going to become a standard that gets repeated, can we try to clean it up and make it as correct as possible.
The first issue I have is the location of the battery. All BB cars DID NOT have the battery located in the left fender with a bag for the windshield washer. I believe this maybe true for a BB with AC but not for ALL BBs. The way the list reads to me is all BB (with or without AC) and SB with AC had the battery on the left side. Correct me if I read the list wrong.
My early 66 BB (Dec 65) has the battery on the right side and has a bottle for the windshield washer on the left side.
a66bbvet is offline   Reply With Quote
Old 09-01-2011, 07:59 PM   #10
Blkblt
CF Senior Member
Blkblt's Avatar
Mine also. November 1965.
Blkblt is offline   Reply With Quote
Old 09-01-2011, 08:13 PM   #11
66L72
CF Senior Member
Support Corvetteforum!
66L72's Avatar
True, it is ambiguous. But still a good comprehensive list of differences
It should read "all A/C cars have battery on left"
A/C not available on L72; therefore all L72 have battery on the right, as do L36 non A/C cars......
66L72 is offline   Reply With Quote
Old 09-02-2011, 06:29 AM   #12
midyear
CF Senior Member
midyear's Avatar
65 396 cars all had the battery on the drivers side (like an ac car), in 66 427 cars placed the battery on the pass side, just like the small blocks unless it had ac, and only ac cars had the battery on the drivers side.
Old 07-07-2013, 08:09 PM   #13
chevyliddle
Junior Member
Check the redline on the tach. A 300 horse has a 5500 redline and the 327/350 and 427/390 both had 6000 redlines and the 427/425 had a 6500 redline. The solid lifter big blocks also had an 80 lb. oil pressure gage. THe L36 and all small blocks had a 60 lb. oil pressure gage. 1966 and 1967 big blocks will have the hood prop on the driver's side and all small blocks will be on the passenger side. The only big block that had the hood prop on the passenger side was the 1965 396.
chevyliddle is offline   Reply With Quote
Old 07-07-2013, 10:09 PM   #14
66BlkBB
CF Senior Member
St. Jude Donor '13
66BlkBB's Avatar
Quote:
Not true. Every 427/390 that I have seen had the 80# oil pressure gauge, including mine.
66BlkBB is offline   Reply With Quote
Old 07-07-2013, 10:16 PM   #15
Nowhere Man
CF Senior Member
Quote:
Only in 66. In 67 they got the 60# oil gauge
Old 07-07-2013, 11:14 PM   #16
zeus337
CF Senior Member
Cruise-In II Veteran
Cruise-In III Veteran
zeus337's Avatar
66 BB cars have the hood latch arm on drivers side. SB cars have it on passenger side.
zeus337 is offline   Reply With Quote
Old 07-07-2013, 11:36 PM   #17
62Jeff
62Jeff's Avatar
You guys realize this thread was started almost 2 years ago? Not sure the original poster is even watching anymore.
62Jeff is online now   Reply With Quote
Old 07-08-2013, 08:11 AM   #18
DansYellow66
CF Senior Member
DansYellow66's Avatar
Quote:
You have to wonder how this happens as often as it does.
DansYellow66 is online now   Reply With Quote
Old 07-08-2013, 08:51 AM   #19
Mr D.
CF Senior Member
Mr D.'s Avatar
Than that would mean this car is now a BB car.
Mr D. is online now   Reply With Quote
Old 07-08-2013, 09:40 AM   #20
midyearvette
CF Senior Member
midyearvette's Avatar
Quote:
midyearvette is offline   Reply With Quote
Reload this Page Did my 1966 Corvette have a big block engine?
Tags
1966, 427, battary, big, block, corvette, difference, engine, front, identification, idetifying, small, springs, stock, tells
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
66 fuel pump maggiesadie8525 C1 & C2 Parts 2 02-20-2014 10:53 PM
looking for a hood liner boper66 C5 Parts for Sale/Wanted 5 08-24-2013 11:16 AM
Worth it to get a NOM 66 Engine? KM1959 C1 & C2 Corvettes 23 02-07-2013 06:52 PM
Engine pad decode--not a vette... KNIPPS C1 & C2 Corvettes 6 09-20-2012 05:45 PM
66 windshield wiper motor number KC66 C1 & C2 Corvettes 8 08-12-2012 06:18 PM
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
