Temp Gauge as Reverse Tachometer??
Old 04-24-2002, 11:34 AM
Denney
Denney's Avatar
Default Temp Gauge as Reverse Tachometer??
I have noticed on my 66 BB that the temperature gauge acts alot like a reverse tachometer (it drops with increasing revs and rises with decreasing revs). Very repeatable. Anyone ever experience this? To me it looks like there is some stray capacitance or something. Any chance the Teflon tape on the sending unit is contributing to this? Thanks!
Denney
Old 04-24-2002, 06:11 PM
hot1corvette1
hot1corvette1's Avatar
Default Re: Temp Gauge as Reverse Tachometer?? (Denney)
That is a real weird one. You must have some kind of electrical leakage between the two gauges. Hard to believe that the teflon tape is contributing, but maybe.
Try disconnecting the tach and see what happens.
Mark
Old 04-24-2002, 06:24 PM
waynec
waynec's Avatar
Teflon tape on the sending unit??? Seems to me the sending unit body is the electrical ground to the engine block for the sender, so teflon tape could indeed be the problem by insulating the threads, especially if it was put over all the threads... try cleaning the threaded sender hole in the block with a stiff steel brush and then using teflon tape only on the top half of the threads, or none at all (the softer brass body of the sending unit, along with the pipe threads, should seal fine.
Old 04-24-2002, 06:33 PM
ghostrider20
ghostrider20's Avatar
The teflon tape may be the problem, although the threads usually cut through the tape enough to make a good ground. I would check it though. Also you may have a loose lead wire that may be making a good stable contact at low revs and a loose contact at hi revs, or vice-versa. I had a problem were my temp gauge was reading high and would peg at max temp. Had a problem with an old crusty lead wire. Replaced it from the fierwall up to the sending unit. Works fine now.
Mark
Old 04-25-2002, 12:12 AM
Denney
Denney's Avatar
When I put in the new 454 HO I decided to put the Teflon tape on the sending unit (have done this before on other cars to make it easier to get out in the long haul). What can I say? I am always paranoid about coolant leaks (they make such a mess) :U In any event I will remove the tape (or at least a good portion of it this weekend and let you know if it was the cause. As far as the connector/wiring, I put in a brand new Lectric Limited harness in the engine compartment, so I hope :confused: it isn't that.
Old 04-25-2002, 12:37 AM
magicv8
magicv8's Avatar
To satisfy yourself that the teflon is not the problem, put a batter jumper cable on the sender base and hook it to the battery ground - then run the engine up and down the scale.
Old 04-25-2002, 11:09 AM
64BB
64BB's Avatar
Default Re: Temp Gauge as Reverse Tachometer?? (magicv8)
"temp drops with increasing revs"....
i suppose i'll get flamed for this, but is it not possible that the increasing revs are actually lowering the coolant temperature by incresing airflow through the shroud??? if you can get hold of an infra red temp gun, you can easily check this out. does not really sound electrical as described, unless the temp drop is pretty instantaneous. agree?? is temp drop somewhat gradual??
Old 04-25-2002, 09:48 PM
Denney
Denney's Avatar
Actually, the temperature drop is very much in synch with the engine revs (I would call it pretty close to instantaneous.) It reads pretty high to begin with after it has warmed up (which I attribute to the new replacement sending unit being out of calibration compared to the older units). I would say we are talking swings of 50+ degrees in a matter of the time it takes to rev it up. Up shift and the temp goes back up the 50 or so degrees until it revs back up, and so forth through out the shifts. Realizing I was not very specific in the initial description I can understand how you can interpret it the way you did. Thanks.
Old 04-26-2002, 01:04 AM
wombvette
wombvette's Avatar
I would do a check of the alternator voltages and also look at guage cluster grounds. If by chance the alternator voltages are going down with revs. it could explain the problem. I know thats not normal, but I have seen it happen.
Old 04-26-2002, 07:47 AM
oger
oger's Avatar
Default Re: Temp Gauge as Reverse Tachometer?? (wombvette)
On a Corvette if anything electrical goes wrong check the ground. Old statement but very true.
Old 04-27-2002, 12:02 AM
Denney
Denney's Avatar
I had a chance to try Magicv8's advice of hooking up a jumper cable from the sender base to a good ground (the intake manifold) and reved it up after warming it up (there's nothing quite as intoxicating as rapping up a big block in the garage) :cool:. It appears that the temp gauge was relatively steady (it did still move a ~little~ with revs), so it appears that removing the Teflon tape is the next step. Will update once completed with results...
Old 04-27-2002, 04:50 PM
ghostrider20
Might want to check to see if the block is grounded well or grounded at all.
Silly but might be something as simple as that.:smash:
Mark
:smash:
To Temp Gauge as Reverse Tachometer??
Quick Reply: Temp Gauge as Reverse Tachometer??
