Inside rear view mirror wont stay in position..
Hello
My inside rear view mirror keeps moving down when i drive my vette...Its driving me crazy.. I tried super glue on the ball to keep it in position...I think it workrd for about 5 miles before it started moving down again...There has to be a better solution..Any ideas are welcome..
Pete
Pete
I bought one for my car because I wanted a day night mirror and I got it from truckandcarshop in Kalifornia... They come to Charlotte's AutoFair every year and the price was half the price of the Corvette Parts houses....
page 65
http://www.scribd.com/full/31943817?...w7lh07v88vrx16
Dave
page 65
Dave
page 65
Dave
page 65
Dave
Don
Easy fix, gentlemen.
There's a square bushing that's supposed to be in the "ball joint" of the mirror, and for reasons that do not make sense, repro mirrors (some, perhaps not all--mine is one) ship without them.
It's a $2 part: see this link from Long Island Corvette. Search for mirror bushing. Other Corvette parts places have them too.
http://www.licorvette.com/
Im not sure how you do this??
Pete
NazTheGreek (12-28-2023)
Hello
Pete
Pete
To me, loctite on the mirror joint is a bad idea, because you're fixing the part that isn't broken to compensate for the part that is actually the cause. And a working ball joint, as opposed to one that's glued or secured with loctite is worth spending $2 for the mirror bushing.
It's nice having a mirror that can be adjusted, as opposed to a glued in place one. I have always had bad luck with glue (always seem to glue something I don't want to) or loctite on fittings that weren't intended to be used with loctite.
Pete, I sent you a PM--the mirror bushing goes in the mirror bracket (or the bolt hole stem on the mirror; it's whichever of the two is inside the other, so the bolt passes through the bushing--cannot remember without taking the mirror out of the car), by removing the bolt that goes through the short ball joint stem on the mirror. The ball joint in the mirror is not the problem--the problem is insufficient tension in the mirror stem joint between the mirror stem bolted to the car and the mirror it attaches to. Without the bushing, you can tighten that bolt all you want and the mirror will keep dropping.
label it as you like,,, i've made a lot of parts for my cars, that work fine,,, some guys have a thicker wallet than me, so tehy buy "repro parts", i can make them,,,
There are two places the mirror can move, one between the mounting bracket and the mirror ball stud arm, and one at the ball stud itself inside the mirror. You need the mirror bushing in place to stop movement between the mirror support bracket and the mirror mounting stem, where the mounting screw passes through to mount the mirror.
The second place you can get movement is at the mirror ball stem itself, it's inside the mirror and held by a piece of spring steel, which has probably lost some of its tension over the years. Not much of a cure for this problem other than replacement of the mirror and housing, you can't get to the ball inside the mirror without removing (and breaking in the process) the mirror glass. I've never seen a suitable process for removing the glass in an interior rear view mid-year mirror.
Dave
Pete: Mine does the same thing. When I put the body back onto the frame I mounted it hard, just like the factory. No cushions means lots of vibration making it right up to the top of the windshield frame and right down through the mirror mount to the mirror.
Kind of sucks but I go with the Cannonball Rallye theme of; whats behind me is not important.
Rich
Rich
i could see you "didn't understand", thats why i corrected you, theres more than one kind of lock tite, its adjustable and works fine,,,
Won't be making Richmond. The pictures of that Black 67 under the hood don't come close to seeing it in person. Last week I was at Jeff's place and we changed out the front hubs on my C5. Before you had to be right up on the car to see the top of the induction system. NOT ANY MORE ! ! ! You can stand 25 feet away and it visually starts calling to you to come over and look closer.
Hello
Pete
Pete
Pete,
If it is the ball area that is causing the problem I am not sure that there is a fix. I had the same problem. Tried to fix it by putting small taps with a center punch. I cracked the mirror in mine. Bought another one off of the internet and it was faulty. It would droop due to the bushing not being inserted where the screw goes through on the mount. Finally purchased another one off of the internet that had the bushing and now "no problem". I don't know if you are going for judging or not. If not, then any replacement mirror should work. You just need the bushing to hold it in place. Don't know if this helps your situation or not.
Steve
