4 Post Car Lifts
You will not be disappointed in your direct lift. I purchased 2 for my shop a couple of years ago and am very pleased.
I have had a DirectLift for over 6 years and am as satisfied with it as the day I bought it.
Regards, John McGraw
love mine has no name but many in my town has them and also love it
http://www.completehydraulic.com/lif...cl08000cs.html
$2,100 delivered including tax
I've had my Direct Lift for 2-3 years now, absolutely love it. It was around $2,000 delivered, about 4 hours to erect, and came complete with ramps, jack bridge, two oil drip trays, and caster wheels to allow easy "roll-around" in case you ever need to do so. It's one of the few lifts being sold that is ANSI tested and certified by the American Lift Institute. Great lift at an unbeatable price, wish I had purchased it 10 years earlier when I first built my house and shop.
It's completely self-contained, no need for a separate air compressor, and the hydraulic pump runs on 110 power, at least for the 8,000 lb. rated model.
Do a search for Greg Smith and Direct Lift, lots of data online there for this and other models as well.
Is storing a vette on a 2-post a no-no? Winter month storage and then realistically 2-week stretches during the summers between drives. Seems like it would be so much more versatile for actual work, but for storing the 4-post is probably better with the suspension not hanging at full "droop".
Also, for those with 110v lift motors, what size breaker do you have for that circuit? I keep seeing 220v/60hz/1phase or 110v/XXhz motor specs, but I can't figure out the amps with that info.
Thanks,
Brian
Thanks,
Brian
BendPak HD12SS 6 years, no issues.
No hassle with ramps since they are attached and swing down as the lift goes up.... However, in the pics below I have the ramps held up so I could drive the Camaro underneath....
Thanks,
Brian
Thanks,
Brian
#34
Jim
#36
I've often wondered why 4 posts seemed to be preferred over 2. It seems like it'd be easier to work on the car with a 2 post and they take up less room. I don't intend to store a car on one so maybe that's the biggest reason 4 posts are preferred.
#37
I've done brakes, suspension work, rotated tires and transmission R&R without any problems with my 4 post. Personally, I wouldn't buy a 2 post even if they were 1/2 the price of a 4 post.
Jim
#38
Received 1,894 Likes
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
There are many reasons most prefer a 4 post. They are easier to put your car on, no bending down to set the arms, you don't have those two big posts to smack your door into and they always seem to be in the way, the car is more secure/stable on a 4 post , you don't need thicker concrete, you don't have to anchor them and they are movable. These are the reasons my friend with a 2 post wishes he bought a 4 post.
Jim
Jim
JIM
#39
The Direct Lift PP8 looks exactly like my Double Park lift including the motor, tank, locks, ramps, etc. Was the DP replaced by the PP8 (meaning did they buy DP)?
Not the best picture but you can see the end of the DP. It sure looks familiar. I understand DP went belly up though. Just curious. I am thinking of selling the DP and also my Mohawk A7 which both are in great shape. Wanted to see what they compare to.
#40
You gotta compare the latching systems. Direct Lift has several versions I think. Some use welded on blocks...which had better be really well welded. The better Direct Lift versions use the Rotary style design with the *floating* plates with slots in them suspended by their ends. Of course that weld better be good too..but I've really liked them so far. If for some chance your garage isn't dead level they allow you to easily level the lift also. I heard Rotary (which was always parent Co of Direct I think) had taken it over completely recently.
When I bought mine, they allowed me to go to a huge warehouse that lots of vendors pulled from. I was able to see a lot of brands assembled and was able to see what failed when the warranty guy walked me through the good and bad of each lift. When it was all done I did the Direct Lift Pro Park 8 plus and later a Pro Park 9.
JIM
JIM
