Splined hub removal
Splined hub removal
What are the correct size bolts that screw into the steering wheel hub enabling you to remove it off the splined steering shaft with a wheel puller.I have several bolts that came with my wheel puller but none fit.I hope the threads are not ruined.Thanks.
"DUB"
....of course you can always try the smash and pull technique. Get a thick 7/16 SAE (fine thread) nut, thicker than the part of the steering column that protrudes through the steering wheel hub. Pull the steering wheel toward you and pop the nut a couple of times with a 3# hammer. Worked for me every time.
