How To - Headliner Install in 65 Coupe
Old 04-24-2011, 12:53 PM
62Jeff
Support Corvetteforum!
62Jeff's Avatar
Originally Posted by BB64VETTE
Jeff, All,
Perfect timing! ... Again thanks for the taking the time to post.
Bo
Hi Bo, you are exactly the type of person I had in mind when I posted my results, someone who just wanted a little insight.
Congratulations on your progress, and ploease do show us pictures!
FYI, the chrome trim on my car is not correct, it should be painted but a previous owner added a few chrome accents to the interior, and I plan to keep them as is.
Old 04-24-2011, 09:55 PM
BB64VETTE
BB64VETTE's Avatar
Default Learning
Jim--progress today but as with all things vintage auto there were some set backs. Posting some pictures and a few other notes for those who may have their car "in boxes." Of note, two of the screws are a different size. All screws are a #8 x 1/2" except two that are #8x1". Those two go into the inner most mounting point on the left and right side molding (a pillar molding) according to the factory assembly manual. I had tried to attach the side moldings (above the door) ahead of the A pillar molding--no can do on a 64 at least. So, I have now gone with this sequence for installation of interior trim:
1. Lower molding (at base of windshield)
2. Upper molding (that rear view mirror installs on top of)
3. L and R side A pillar moldings
4. Side molding (above the door--sliding these into the recess of the A pillar molding)
5. Halo panel (mine was out so just made it all easier)
My A pillar pieces did not fit right and still working them a bit to get to match the upper molding.
I do recommend taping up the side of your new headliner--my side pieces had some sharp edges on them and left some small marks.
I also had to move back the insulation that was in place to find the very small holes for the top screw to go into place on the A pillar moldings--not obvious at first blush of the project.
I also used a small pick to help align the holes in the trim to the clips as I worked the trim into place
I used the Al Knoch repop headliner and it was a perfect fit.
Thanks again!
Bo
1960 (05-01-2021)
Old 04-24-2011, 11:21 PM
Pilot Dan
Pilot Dan's Avatar
Originally Posted by woodsdesign
Just wondering, when you install dynomat under the headliner is there any concern about the thickness? Especially by the edges where the trim is attached.
No, the Dynamat is very thin and not an issue at all. I installed it under my factory original headliner with no problem and was very pleased with the results. Pilot Dan
Old 04-13-2012, 11:29 AM
watson
watson's Avatar
I am curious about the chrome trim pieces at the windshield and A Pillar. I have never seen those before. My car has painted trim in the same color as the interior. Did you add that or did that car come with them?
Thanks,
Doc
Old 04-13-2012, 11:43 AM
62Jeff
62Jeff's Avatar
Thanks,
Doc
Previous owner did that
Old 04-13-2012, 01:07 PM
watson
watson's Avatar
It looks like it works well with the silver interior.
Doc
Old 08-20-2013, 05:58 AM
Chalie M
Chalie M's Avatar
Great write up will help me when I acquire my C2, couldn't help but notice what looked to be blow up pics of electrical diagrams on the
wall in one of your pics, if so where did you get them.
Thanks again
Old 08-20-2013, 08:40 AM
62Jeff
62Jeff's Avatar
Thanks again
Thank you. Forum member Don Olson (Vetsvette2002) sells them
http://forums.corvetteforum.com/memb...vette2002.html
Old 03-12-2014, 07:04 PM
DZVette
DZVette's Avatar
With Jeff's approval, attached you will find a PDF version of his Headliner "How to" for you to download at your convenience.
Dave Z
Old 03-13-2014, 06:07 PM
62Jeff
62Jeff's Avatar
Dave Z
Thank you Dave, I appreciate your efforts.
I think I'll ask the moderators to remove this is a Sticky now, as there are too many stickies on the forum these days.
Old 03-21-2017, 09:03 PM
rld
Cruising
rld's Avatar
Default Sagging C2 coupe headliner 1966
I have replaced my headliner twice now and both times it has come unglued .I bought the first one from Corvette Central,they replaced it.Now the second one has failed. I live in florida,but it is in garage most of the time. The fit is great and not hard to install.Can someone help
Old 03-21-2017, 09:51 PM
Frankie the Fink
Frankie the Fink's Avatar
Received 7,082 Likes on 4,736 Posts
Army
I had the same problem with a Corvette America piece; the adhesive failed the FIRST time I took the car out in the heat...
I returned it and got an Al Knoch headliner and no more problems - I live in Orlando...
rld (03-26-2017)
Old 03-21-2017, 10:14 PM
  #33
MOXIE62
MOXIE62's Avatar
Originally Posted by 1snake
Since this thread is about a 65, that's what I thought we were talking about. Your quote from the Zip catalog is referring to hardtop headliners. It also says "Coupe headliners are all vinyl". That may be what they are selling but that's not a correct statement regarding the originals.
Jim
That's not the only "not a correct statement" in their catalog.
Old 03-21-2017, 10:26 PM
  #34
W Guy
W Guy's Avatar
I wash someone would post a "how To" piece like that for a '64 convertible hardtop.... One is on my agenda.
Verne
Old 03-26-2017, 09:05 PM
  #35
rld
Cruising
rld's Avatar
Thanks for the post. It makes me feel better.I though I was doing something wrong.
Quick Reply: How To - Headliner Install in 65 Coupe
