Car won't stay running
So I decided to wake up my 66 after it's winter slumber. The car won't stay running, I have to have my foot on the throttle. That being said, I probably did that for about 1 minute, maybe 2. Should I just do that longer or do you think something is up?
Received 1,844 Likes
Choke is stuck or your needle/seat has some dirt in it.
Good 'a guess as any!
Not sure if this applies but I installed an in-line fuel filter. I usually change it after the first drive after hibernation just in case some gunk accumulated somewhere in the tank or fuel lines and is now pugging the filter and preventing enough gas from getting to the carb.
Worth at least starting with the really easy, cheap fixes first.
My 2 cents
My 2 cents
Check the choke first to make sure it is working properly. Not sure what motor, carb, etc you have. I know my motor which is a new 383 stroker crate motor has a fast idle that keeps the RPM up during warm-up. My motor does not like to run good until it hits at least 120 to 140 degrees. Ya have to remember these motors are not like our daily drivers. You have to warm them up to get them happy!
Thanks for the reply guys. Quick question... (sorry, I'm not a mechanic or anything). The car has an automatic choke correct? If so, I take the air cleaner off to access the carb, but what exactly am I looking for?
I have a 327/300 HP engine.
Thanks!
Thanks!
Take the air cleaner lid off. On the front half of your carb you will see a piece of metal ( flap) that opens and closes over the bowls. When the engine is cold and you pump the acclerator once before starting, that should close the flap ( down position). Take a look and see if it is open ( flap vertical) or closed. If you need a pic let me know but it should be easy to spot.
The choke linkage is also responsible (in most cases) for getting the carb operating at a fast idle via a fast idle cam in addition to temporarily enriching the mixture. If you get the choke to close when cold and start the car and it isn't idling from around say 1,600-1,800 RPM check the fast idle linkage.
I haven't looked at the carb yet. I will this afternoon, but when I was in the garage this morning, I noticed a pool of gas on the intake manifold. Does that point to something? Thanks again!
Before you start it again, dry up the gas on the intake so you don't get a big fire started. Then have someone start the car while you watch what is happening with the air cleaner off.
If gas starts coming out one of the little tubes on top your carb, your float is stuck open. You can try capping off the gas line, starting the engine and running it until it quits, then hook the gas line back up and see if it's fixed. Otherwise, time to take the carb apart and blow it out.
If you engine has a Holley on it, you could just have shrunken gaskets and the carb is leaking internally/externally. If that's the case, you can buy new gaskets, install and your problem will be fixed. If you see a Holley leaking at the gaskets, resist the temptation to cranks the screws tighter. All you'll likely do is warp the metering blocks and the main body and then you will have a problem.
Yeah, it points to post #3. Sounds like the carb is flooding.
Look -- you have to 'blip' the accelerator linkage to get the choke to close on a cold car.
The linkage will hold the choke from closing all the way when cold until you do this !!
He said he had to keep his foot on the gas. That should trip the choke.
Besides, a non working choke doesn't explain his puddle of gas on the intake.
Don't want him chasing bogus symptoms...
If the choke plate won't move, something is hung up.
I don't know what carb he is running....a Holley was discussed briefly above. In any event, I don't disagree Mike. The gas puddle on the intake is a giveaway that something is causing flooding or there is a leaky fuel line/filter.
