1960 speedometer cable
Old 04-08-2011, 10:02 PM
JAMES69
JAMES69's Avatar
Default 1960 speedometer cable
I am trying to install a speedometer cable on my 1960 vette. Does anyone have a picture or drawing of where it actually goes on the tranny. I have it up on the lift and its not that obvious. Sorry for asking something this obvious,
Jim
Old 04-08-2011, 11:17 PM
Frankie the Fink
Frankie the Fink's Avatar
Received 7,082 Likes on 4,736 Posts
Army
You don't say what kind of tranny - the drawing and pic are of a '61 B-W 4-speed.
Old 04-09-2011, 08:00 PM
JAMES69
JAMES69's Avatar
Default Thanks
Frankie,
Thanks for the pictures. I checked the trannie and its a T-10. I put the cable on this afternoon, it was just the spot you suggested.
thanks again,
Jim
Old 04-09-2011, 10:19 PM
Frankie the Fink
Army
No problem. Glad to help.
Old 08-08-2014, 10:52 AM
mathmanmitch
1st Gear
mathmanmitch's Avatar
Hi and thanks for the above advice. My issue is removing the nylon gear itself. It does not come out with the speedo cable, nor does it want to come out past the fitting. Do the
retainer, fitting and seal need to be removed to slide out the driven gear. Secondly, since mine is chewed up and fairly new and I have a 3:55 rear end, is it possible that I am using the wrong size driven gear. (have a '65 T-10 4-spd in my '61). If so, how do you tell the size of the drive gear without pulling the tranny apart? Thanks
Old 08-08-2014, 03:41 PM
JohnZ
Support Corvetteforum!
JohnZ's Avatar
Received 1,857 Likes on 1,100 Posts
The entire package comes out at once - the fitting, seal, and driven gear - the gear can only be removed with the fitting out of the transmission. I don't know where your post came from, so I don't have any background on your problem - this thread is three years old, and you weren't in it.
A 3.55 axle takes a 21-tooth red driven gear.
To 1960 speedometer cable
Quick Reply: 1960 speedometer cable
