C1 Remote Trunk Release?
Old 03-23-2011, 10:05 AM
Airetime
Airetime's Avatar
Default C1 Remote Trunk Release?
I have had a Halon Fire extinguisher for awhile now and it is time to install it but because it is not the really small type that usually is used it just doesn't look right in the cockpit. So it has to be installed in the trunk, actually I am using a Drake extinguisher holder/release just inside the trunk behind the trunk latch All that is great BUT as you know I still have to use a key to pop the trunk and in case of a fire, I don't want to stand there watching things go up in flames if I don't have the key
My Question? Has anyone installed a remote cable and hooked it up to the trunk latch? If so can I tap your knowledge??
Old 03-23-2011, 10:11 PM
vettefred
Support Corvetteforum!
vettefred's Avatar
Use an electric trunk opener solenoid from any 80's GM G body. Preload trunk lid with small spring (like on 62 vette). Yellow button and wiring could be placed anywhere inconspicuously.
Fred
Old 03-23-2011, 11:58 PM
TroyPyles
TroyPyles's Avatar
My Jaguar XKE had a cable operated trunk release. A chrome handle was located behind the passenger seat. Perhaps that set up could be adapted.
Old 03-24-2011, 07:04 AM
Frankie the Fink
Frankie the Fink's Avatar
Received 7,085 Likes on 4,737 Posts
Army
Don't know if I want a gas tank between me and my fire extinguisher...or some cobbled together aftermarket mechanism to get to it. Get a smaller extinguisher.
Old 03-24-2011, 09:15 AM
Airetime
Airetime's Avatar
Default Small Fire Extinguisher
Thanks for the suggestion but have you ever had to use a small one? They are a pretty much a one blast unit. Like HP/Torque, I'd rather have more than enough than not enough!
Old 03-24-2011, 09:36 AM
Procrastination Racing
Procrastination Racing's Avatar
That reminds me of a race at Moroso one weekend. I was working Turn 9 with some friends and this guy in an old circle track car he converted to road racing caught fire going past us into 10. Turn 10 responded, signaled for help, and three of us from 9 responded when they couldn't get it out.
We went through 10 regular bottles (not something small like you have in a car) before the fire truck was able to pull through the paddock to get there.
This was an engine fire on a metal car. You really don't want to see a plastic car burn.
Frankie, that little bottle in the glove box is best used to put out that cigarette that fell on the floor or if the air cleaner catches fire when the carb backfires. Anything else, you will have better luck ripping your jacket or shirt off and smothering it.
Old 03-24-2011, 09:50 AM
wmf62
wmf62's Avatar
St. Jude Donor '07
yep it's a sad sight....
i now carry a BIG fire extinguisher in the trunk.
Bill
btw: i had had the same thought about adding a remote trunk release for the very same reason
Old 03-24-2011, 09:57 AM
62Guy
62Guy's Avatar
On my first 62 the previous owner mounted a cable with a pull button in the glove box to the trunk release. Worked great, which was a good thing cause the key never worked in the trunk lock.
Old 03-24-2011, 11:29 AM
Frankie the Fink
Army
In the time it takes you to: a) remember you have a "big" extinguisher in the trunk, b) mistakenly run back towards the trunk with the key because in the excitement you forgot about the hidden trunk release, then, c) run BACK to the cockpit release the trunk and get the extinguisher....I'll have doused any fire I care to tackle with my little guy 1 second and 1 click from my right hand. Anything bigger than that and its an insurance claim IMO.
Anyway, I've put out one engine fire on the car already with an A/B/C extinguisher the same size....and had to clean up the engine for a whole day afterwards.
Old 03-24-2011, 12:50 PM
wmf62
wmf62's Avatar
St. Jude Donor '07
lol...
Frank, if you run back with the key; then you don't need the button....
i have a small spray carbon tet extingisher in my console box (suitable for a kitchen fire), but neither mine or yours might not have saved my front end from what was a gasoline fire; a BIG A/B/C probably would have and i'd have gratefully cleaned up the mess (and i would have had all the time in the world to open the trunk)... so, i stood by and watched it burn; the only thing that kept it from being a complete loss was the the top was up and the windows were up and so the fire essentially snuffed itself out.
the fire was so hot that the upper a-frames just folded over...
Bill
Old 03-24-2011, 02:31 PM
Frankie the Fink
Army
Originally Posted by wmf62
lol...
Bill
I was on the streets of Washington DC when the plane hit the Pentagon -- you should just see what people do in the face of a disaster...
FTF
Old 03-24-2011, 03:45 PM
Airetime
Airetime's Avatar
Default If'n you gots da key in yer hand, use it?!
"IF" I had a key in hand, I don't need to use the cable release. This is kind of like saying don't lock your door because it's inside and you might not have the key with you. Frankie if you can put out that fire in 8-10 seconds, good for you, but what if you run out and the fire isn't out?
I will say that at least you have a extinguisher in your car, I can't tell you how many don't. It is pretty sad to see someone about to open a smoking hood without one. I have owned my Corvette longer than most and it can't be replaced. Carry what you want but give me a decent size Halon anyday!
Old 03-24-2011, 04:51 PM
Frankie the Fink
Army
I'd estimate 15-20 seconds to put out my engine fire...that includes trying to throw an old flannel shirt on the burning manifold (totally useless gesture)...then getting the fire extinguisher and it wasn't more than 2-3 squirts and the fire was out. Any longer than that and it would have been 9-1-1 time and clear out for the experts to go to work. I'm not dying or even getting 2nd or 3rd degree burns over a machine...no matter how nice.
Old 03-24-2011, 09:42 PM
Airetime
Airetime's Avatar
Default From your pic of your little extinguisher...
From the pic of your fire extinguisher, it appears to be a Halon, if so the discharge rate is about 8-10 seconds so it must have taken you 5 to 10 seconds to throw and remove the "flamable" flannel shirt (why did you do that?) :o You can usually blow out a carb fire due to a backfire.
Oh well, as I said before and I ending this discussion with "I'd rather have more than enough rather than not enough! HP, Torque and fire extinguishers..
BTW, I have owned and held onto my 1959 Corvette for going on 42 years now. Cheers
Old 03-25-2011, 07:42 AM
Donny Brass
Donny Brass's Avatar
C2 of Year Finalist (track prepared) 2019
2017 C2 of the Year Finalist
maybe this is the answer you are looking for:
Old 03-25-2011, 07:53 AM
Frankie the Fink
Army
My fire occurred in my garage before I had the fire extinguisher in the car so I after the non-effective shirt deal I had to run across the garage and unlatch THAT extinguisher from the garage wall...sorta equivalent to getting one out of your trunk .. ya think ?
Old 03-25-2011, 08:02 AM
wmf62
wmf62's Avatar
St. Jude Donor '07
bottom line... whatever you did worked... and saved the car AND the house...
Bill
To C1 Remote Trunk Release?
Quick Reply: C1 Remote Trunk Release?
