Frame in Jig
Frame in Jig
Thought I would show you some photos of my 64 frame in a GlobalJig Jig, the frame was not close to the blueprint, the rear wheels had close to 1 inch difference, so one wheel was sitting 1 inch closer to the front of the the frame than the other, just wondering how straight/blueprintet they were from the factory?
Received 1,762 Likes
ttt
Looks like you are going to do it correct man. Are you going to weld the frame up all the way. When I do this I am going to weld mine totally up all the way. Had a friend that did and the car drove a ton better.. Robert Post more pic,s as you go on this. Us old guys love to see pic,s
Unless the car was whacked real bad it seems 1 inch is beyond any factory spec..Old addage...measure twice cut once...I would set the jig at measuring points listed on the fact specs, then measure the other mounting points.
When I did my frame (modded a 79 to fit a 66) I measured crosswise using as many landmarks as I could find from the specs. Think the biggest difference was 3/8 in front to back.
Biggest problem was making the body mounts correct height and fore and aft!!!!
Please do man, see some of you guys in denmark like to go fast also. I like the motor in your pic,s..... You will like the frame fully welded up a big diff in the ride and taking the curves in the road with it.....
Received 1,859 Likes
Nice - looks great! Don't forget to add the missing hole for the bolt that attaches the rear of the left lower control arm shaft to the frame bracket.
