Need Advice
Need Advice
It is time to redo the folding top for my 1960. I discovered that the top that came with the car is for a 61-62. Do I replace the rear bow at a cost of over $300 or use the frame as is? No need to be origional. I need to buy new inner and outer attach brackets. They have different part numbers than the earlier ones. Does anyone know what the difference is?
Thanks for any help or advise.
Dave
Dave
Regarding the attachment brackets, there are three pairs. The large, basically flat V-shaped brackets, also called 'pie-plates' are the same for 56 on up to 62, as far as I know. The inner brackets are also the same for those years but the outer brackets are different and one version fits 56-60's and the other fits 61-62's.
Mike T.
Mike T.
2023 C1 of the Year Finalist - Modified
2022 C1 of the Year Finalist - Modified
2020 C1 of the Year Finalist - Modified
2019 C1 of Year Finalist (performance mods)
2018 C1 of Year Finalist
Depending on how original you want it, you could buy the rear deck lid to fit the frame. Not many people would ever notice it. It would probably cost a little more because it would need to be painted.
Received 1,762 Likes
ttt
By your statement just do the fix on it and make it look like new with your work. No need to spend two times the money for nothing...
Thanks for the input guys. I think the rear bow will be alright and will seal good enough. I still would like to know if the outer mounting brackets are different on the body end or the top end. Otherwise I will have to order both and send one set back.
Dave
Dave
Received 4,583 Likes
C1 of Year Finalist (appearance mods) 2019
I would first put an ad up here and perhaps in Hemmings etc, looking to trade for the right one. You never know someone out there might be in the same position as you are. There were more of the early ones than the 1+2's made. Just an idea.
Received 6,547 Likes
C2 of Year Finalist (track prepared) 2019
Dave
Dave
From the way you are asking your questions, I have the feeling that your soft top is not presently installed on your '60. True?
Assuming so, here's what you need to know: The later soft top will bolt directly to the existing mounts on your '60 and the header latches will mate with the receivers at the top of the windshield.
However, the swinging wire loops on the rear bow will not line up with the latches on the rear deck. You will need to invent a way to shift the swinging wire loops by.... an inch or so (don't recall exactly).
As for the contour of the rear bow, it is very subtle. Unless you point out that you have a '61 -'62 soft top, I doubt that anyone will ever figure it out. In fact, I'm aware of a '60 in northern California that has a '62 soft top installed which has gone undetected for a very long time.
Jim
Thanks Jim
When I got the car the top was latched on but not attached to the car.
No brackets. They may have relocated the rear latches. I will have to investigate that. You have given me the info I need to proceed.
Thanks again.
Dave
Thanks again.
Dave
Dave, after seeing Jim's response, it seems I misread your initial post. I was thinking you had the wrong 'series' of outside soft top brackets when all along you had all the correct brackets for your '60 and were asking only if the 61-62 soft top frame would fit them. As Jim pointed out, the answer is yes it will. The placement of those rear trapeze latches should be your only concern.
Mike T.
Mike T.
