1967 Corvette VIN Numbers.
Old 02-09-2011, 11:20 PM
mdfunky7
7th Gear
mdfunky7's Avatar
Default 1967 Corvette VIN Numbers.
Hello,
I posted this in the wrong place last time & with a wrong title, so I will try again. I'm new to the forum & hopefully this will be correct.
I have a 1967 Corvette convertible and I would love to know if anyone could give me any information about it from the vin number. I have owned the car for quite a while & it has a 427, 4 speed in it. I have no idea if it is the correct engine and it's a weekend driver and not an all original car.
The vin number is: 194677S104759
Thanks in advance for all the info & comments,
Mike
Old 02-10-2011, 01:02 AM
1965fuelie
1965fuelie's Avatar
2018 C2 of Year Finalist
Hi and welcome.
The VIN will not tell you much, but:
You got a 1967 convertible
It is the 4759th Corvette buildt for 67
Your car left the assembly line nov.28 1966
Thats it
Post what you see on the trim tag and you will get some more information, but not if it was a 427 originally.
Old 02-10-2011, 01:09 AM
5thvet
5thvet's Avatar
Your post was transferrred over here. Look at your original post about 10 down from this one.
See here.
http://forums.corvetteforum.com/c1-a...ew-member.html
Old 02-10-2011, 10:46 AM
Black_Magic
Black_Magic's Avatar
2020 Corvette of the Year (appearance mods)
C2 of Year Winner (appearance mods) 2019
CI 4-5-7-9-10-11 Car Show Winner
CI 2-3-4-5-6-7-9-10-11 Vet
Here ya go ===> Birthday Calc
George
Old 02-10-2011, 02:31 PM
mdfunky7
7th Gear
mdfunky7's Avatar
Thanks for the info.
There is no trim tag on the car.
Any more suggestions ???
Thanks,
Mike
Old 02-10-2011, 03:13 PM
LB66383
LB66383's Avatar
Yeah....you're screwed.
Old 02-10-2011, 03:17 PM
JohnZ
Support Corvetteforum!
JohnZ's Avatar
Received 1,857 Likes on 1,100 Posts
Thanks,
Mike
You'll have to do some detective work on the "clues" to the car's history and configuration and numbers on components to dope out what's original and what's not. There's lots of help here to figure those things out.
Old 02-10-2011, 03:20 PM
VG
Virtual George
VG's Avatar
Navy
VIN decode:
http://www.decodethis.com/PatternDetail.aspx?id=51
Look for the last few digits to be stamped on your engine pad.
VG
1967 Chevrolet Corvette Convertible
1 Line Chevrolet
94 Series Corvette 8 Cyl.
67 Body Convertible 2-Door
7 Year 1967
S Assembly St. Louis, Missouri
104759 Serial 104759
Old 02-10-2011, 05:36 PM
shooter1951
shooter1951's Avatar
Since the trim tag is gone the chances of this is probably slim to none........... HOWEVER you could get EXTREMELY lucky.............and find that the built sheet is still on the gas tank.
If you want to check this you can do it by removing the fuel door and use a mirror to see the top of the tank. An hour's job at tops. If you do see it is there then post again for instructions on how to retrieve it.
Old 02-10-2011, 05:43 PM
shooter1951
Scratch that, I just saw it was posted on the original thread.
Old 02-10-2011, 09:23 PM
mdfunky7
7th Gear
mdfunky7's Avatar
OK, here is a little more info. The numbers on the block are 3904351, and the heads are GM aluminum, but I haven't had time to pull the valve covers off to get the number off of them. The block has obviously been decked, because there is nothing visible to read on the front pad. The front sway bar is 7/8" and I guess I will check on top of the gas tank this weekend to look for a build sheet, but I doubt I will find one. Anyway, I just thought I would add a few more details.......Thanks for the help.........Mike
Old 02-10-2011, 11:39 PM
5thvet
5thvet's Avatar
At least you have one of the correct engine block casting numbers.
Old 02-11-2011, 11:13 AM
SupremeDeluxe
SupremeDeluxe's Avatar
2015 C2 of Year Finalist
Agree, hard block to find.
Old 02-11-2011, 10:42 PM
LT1driver
LT1driver's Avatar
blocks easy to find if you have the $$$$$$$$, look at fuel line where it connects to rubber hose which goes to fuel pump, look at angle, this gives a clue if big or small block. look at tach redline, oil pressure gauge should go to 80psi, rear end should have caps not u-shaped strap on the rear end to half shafts, rear end code will tell if big or small block. of course, many of these things could have been changed but this will give you a general ideal what car probably came with.. other option is try to retrace owner history and talk to owners....good luck.
Old 02-12-2011, 07:43 AM
Mossy66
Mossy66's Avatar
St. Jude Donor '14
Also look at the throttle linkage. they were different for big block.
Old 02-15-2011, 11:35 AM
mdfunky7
7th Gear
mdfunky7's Avatar
Thanks for all the help. I knew it wasn't going to be easy......Mike
Old 05-21-2013, 11:36 AM
tjcstuff
2nd Gear
tjcstuff's Avatar
Default block number location
I have what I believe to be a 1967 327 Corvette engine. Where can I find the block numbers specifically?
Im a little dumb I guess and dont know where to look.
Old 05-21-2013, 12:15 PM
65GGvert
65GGvert's Avatar
Received 3,220 Likes on 2,302 Posts
I see you're a new member, so welcome and a little advice. Don't post your question is someone else's thread. It confuses the answers whether for the original or later questions. Click on "new thread" at the top left and start your own thread for specific answers to your questions. (it's also against forum rules, known as hijacking) HTH
To 1967 Corvette VIN Numbers.
Quick Reply: 1967 Corvette VIN Numbers.
