Dripping fuel lines on carburators
Im having a drip coming from my front and rear carbs on my 427 435. All lines are snug and tight. Anyone have the same problem?
I spoke to a friend of mine and said it could be from the ethanol in the fuel now.
Location: going faster miles an hour...with the radio on in browns mills new jersey
Loosen them up, tighten them down; loosen them up, tighten them down.................then..........loose n them up, tighten them down.
After you've done that a few times, put a brown paper towel or paper grocery bag under the lines. Fire the car up briefly, shut it off and check for leaks. Any leak will show up readily on the brown paper.
You should be good to go.
Others may have different solutions. This worked for me.
If you're are tightening inverted flare fittings, use some anti-seize on the threads and flare part of the tubes. The reduced friction will help get a tighter seal.
Had that problem with a new fuel line install the other day on the 59. On off on off tighten drip tighten drip then finally got it to stop. It was under the car so of course I got covered in gasoline...... several times . At least you don't have gravity fighting you! Pilot Dan
Also, the large fitting to the carb (the one the flare fitting screws into) can leak. Be very careful not to strip it, but it may need a new gasket and a little gasoline proof thread sealer. Also be sure to use a backup wrench on this fitting when you tighten the inverted flare fitting.
Harry
When I was installing my new tank and SS gas lines on my 59, one of the best pieces of advice that someone here gave me, was to "seat" the fittings BEFORE installing everything. This was just a matter of tightening/loosening about 3/4 times to seat the flare. Good advice.
This multi piece arrangement can leak if not aligned well and each fitting/line is fighting the others. I have found this to work for me: Starting with all NINE fuel line fittings loose, carefully tighten the carb inlet, then start slowly snugging up the fuel lines as you wiggle the lines trying to center the flares as best possible. I do the carb flare fitting last while holding the carb inlet in place with a wrench as I tighten the flare fitting. I do this so the carb fitting worn't get over tightened. Lubing the lines as noted above helps too. I've seen the fuel line at the carb get torqued as it was tightened and then cause the carb inlet to back out. I've considered replacing this all with AN fittings and flexible lines. Anyone done this?
Flex Hose
Of course, the AN fittings never leaked, and this is a blessing!
Received 1,859 Likes
There really isn't room for the AN fittings required; if you use conventional steel fuel lines instead of stainless, the installation is generally leak-free. The double-flares on stainless lines are very hard, and can damage the flare seats in the brass blocks before they seal.
Harry
I actually think he is talking about the large fitting ( about a 1" open end wrench). It's pretty easy to get a wrench on a single 4bbl, but the tri power set up looks very tight. Holley used to make a special wrench for it, but I have not seen one in years. What are the other tri power guys using?..
Harry
Harry
