Go Back   Corvette Forum > C1 & C2 Corvettes, 1953 - 1967 > C1 & C2 Corvettes
Register Forgot Password?
Register Search Today's Posts Mark Forums Read FAQ Vendor Directory
Search
C1 & C2 Corvettes
General C1 Corvette & C2 Corvette Discussion, Technical Info, Performance Upgrades, Project Builds, Restorations Sponsored by
Flaming River
Industries
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C7 Parts & Accessories
C6 Parts & Accessories
C5 Parts & Accessories
C4 Parts & Accessories
C3 Parts & Accessories
C2 Parts & Accessories
C1 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 11-18-2010, 09:35 PM   #1
65specialk
CF Senior Member
65specialk's Avatar
Default 15x6 JJ code wheel
Is this a Corvette wheel?? Can anyone ID??
Dave
65specialk is offline   Reply With Quote
Old 11-18-2010, 10:09 PM   #2
GUSTO14
CF Senior Member
GUSTO14's Avatar
Dave, the JJ you've posted doesn't show up on any list I've found as a "Wheel Code", it does show up as a "Rim Code" on a lot of different rally wheels.
http://chevellestuff.net/qd/rally_wheels.htm
Look on the wheel for a Wheel Code next to the valve stem hole. It should correspond to one of the codes in the left column here...
XA 14X5 B-3 1/2 67 Chevy II with drum brakes
DA 14X5 B-3 7/8 67 Chevy II RALLY with disc brakes
DG 14X6 67 Camaro & Chevelle with dics brakes
XB 14X6 B-4 3/8 67 Chevelle SS, 68-69 Chevelle with F-70 Tires, 70 Chevelle
XN 14X6 B-3 3/4 68-69 Camaro & Nova with drum brakes. Different shaped outer
AE 14X6 B-4 3/8 70 Chevelle Station Wagon
XG 14X6 B-3 7/8 68-69 Camaro with dics brakes, 68-70 Chevy II/ Nova with disc brakes, 69-69 El Camino without disc brakes. Wider drop center than normal
DE 14X6 B-4 3/8 71-72 Nova & Chevelle, 6 hole wheels
YW 14X6 B-4 3/8 Exactly like XB, may have come on same cars
YJ 14X7 B-4 3/8 69 Camaro/ Chevy II L72- ZL1, 70 Nova
AV 14X7 70-72 Camaro, 71-72 Nova, 6 hole wheel
XT 14X7 L72- ZL1 Non Rally Wheel
YA 14X7 B-4 3/8 69 Chevelle SS Wheel
AO 14X7 B-4 3/8 70 Camaro &69 Chevelle SS Wheel
DB 15X5 67 Passenger Cars with disc brakes.
DF 15X6 B-4 1/16 67-68 Camaro Z28
DC(BIG) 15X6 B-3 1/2 67 Corvette, No other stampings on rim
DC 15X6 B-3 1/2 68-70 Passenger car, 67 Passenger car (early models)
FI 15X6 B-3 1/2 68-70 Passenger car, 67 Passenger car (later models) Riveted instead of welded together
YS 15X6 B-3 1/2 68-70 El Camino
FW 15X7 B-4 1/4 71-up most any GM
AG 15X7 B-3 3/4 68 Corvette (will take 15x8 Beauty rings)
YH 15X7 B-4 1/4 L72- ZL1 Z28 Rally 69 narrow drop center
AD 15X7 B-4 1/4 L72- ZL1 Z28 Rally 68 wide drop center
AV 15X7 70, 71, 73 CAMARO Z28 5 spoke wheel
AZ 15X8 B-4 69-82 Corvette
This will tell you what the wheels were originally for. This list is not all inclusive by the way.
Good luck... GUSTO
GUSTO14 is offline   Reply With Quote
Old 11-18-2010, 10:50 PM   #3
BLee
CF Senior Member
BLee's Avatar
I think that has to do with the bead design and shape.
Quote:
Dave
BLee is offline   Reply With Quote
Old 11-19-2010, 08:10 AM   #4
gbvette62
CF Senior Member
gbvette62's Avatar
Are they ralleys or steel wheels? 63-66 Corvette steel wheels are 15x5 1/2 (as were the optional 57-62 wheels). 67 ralleys were the only Corvette wheels ever used in the 15x6 size. 65-66 OEM wheels are "J", and the service replacement ones are "JK"s, I think.
gbvette62 is offline   Reply With Quote
Old 11-19-2010, 01:08 PM   #5
JohnZ
CF Senior Member
Support Corvetteforum!
Dave
Nope. No Corvette ever used a 15x6 wheel with the "JJ" rim section code.
JohnZ is offline   Reply With Quote
Old 11-19-2010, 01:12 PM   #6
JohnZ
CF Senior Member
Quote:
'65-'66 Corvette 15" x 5-1/2" steel wheels used the "JK" rim section, and so did the '67 6" rally wheel.
Old 11-19-2010, 06:16 PM   #7
champs65
CF Senior Member
champs65's Avatar
Does anyone have a comprehensive list for regular steel wheels?
My 65 had 15x6 rims with the nubs by the valve stem when I got it...they have a code of FL
I've tried to identify these here and on google and have come up empty.
champs65 is offline   Reply With Quote
Old 11-20-2010, 05:43 PM   #8
JohnZ
CF Senior Member
Those might be the old "8080" Service wheels. Corvette steel wheels didn't have any code stamping adjacent to the valve stem until the 1967 "B", "DC", and "DG" rally wheels. The "JJ" and "JK" stampings referenced above are the SAE rim cross-section design codes, and are stamped in the rim area covered by the tire; '66 rim stampings shown in the photo below.
Old 11-21-2010, 09:54 AM   #9
65specialk
CF Senior Member
65specialk's Avatar
Are you saying the rim pictured is correct for a 66 Corvette?? Dave
Old 11-21-2010, 01:41 PM   #10
JohnZ
CF Senior Member
Yes, it is; 15x5-1/2 JK, manufactured March '66.
Old 11-21-2010, 07:47 PM   #11
65specialk
CF Senior Member
65specialk's Avatar
My wheels are stamped 15X5 1/2 JK 8 64 .
So these should be correct for my early 65?? Dave
Old 11-22-2010, 01:22 PM   #12
JohnZ
CF Senior Member
Yup, sounds good to me.
Reload this Page 15x6 JJ code wheel
Tags
15, 15x6, 15x6jj, 69, canadian, cars, chevelle, code, dg, ii, jj, rally, wheel, wheels, xn
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
