Toms Rear Spindle Setup
I am putting together the trailing arms with Toms 30 spline sindles. I bought the entire setup but I am only talking about the spindles at this time. When I asked Tom how to set up the bearings he told me to preload the bearings to 10 to 15 in*lbs similar to say setting preload on a pinion, typical practice is to have no preload and use .002" endplay on a vette spindle application.
I'm at .002" endplay now. Why the difference in approach? I understand when Tom set these up himself years ago he preloaded the bearings. I posed this question to 632C2 (Steve) and he has 2 cars and one car has preload as Tom stated to do and the other has the .002" endplay.
So again which should be used and WHY
Received 1,874 Likes
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
I set mine from Tom's at .0005" many years ago when I installed them. I recently took them apart to repack the bearings and they looked perfect. Many many drag strip runs, street miles, banzai top end runs and cross country trips. When I put them back together they still ck'd at .0005" with same bearings etc in place.
I would suppose Tom was trying to eliminate any movement at all on them during hard drag strip launches and to allow for slight initial wear. I've always used .0005-.001" and done well.
JIM
JIM
I had the same thoughts as you regarding the initial break in and hammering action when too large of an endplay was used.
Thank you
Dave
Thank you
Dave
