C2 A-arm bushing replacement
Old 10-29-2010, 01:29 PM
JayWay
JayWay's Avatar
Default C2 A-arm bushing replacement
Has any forum member actually replaced the upper and lower A-arm bushings (with inner rubber rings) for any year C2 Corvette?
First challenge is to remove the old bushings without damaging the A-arm or the A-arm shafts. Second challenge is to replace the old bushings with new bushings without bending or otherwise damaging the A-arm itself.
Any advice, guidance and/or counsel will be greatly appreciated.
TIA
Old 10-29-2010, 01:50 PM
Scott Marzahl
Scott Marzahl's Avatar
Use the search function, this has been covered lots of times. If you have a good impact chisel that will take them right out. If not, then use a propane torch to burn the rubber out, knock out the inner sleeve and then use a hacksaw to cut partially through the outer sleeve and then chisel it out.
Old 10-29-2010, 03:23 PM
Tom454
Tom454's Avatar
.... and if you have a copy of the service manual.... there are special Kent-Moore tools suggested by GM to avoid such damage. I have them.... they work great.
Old 10-29-2010, 03:41 PM
claysmoker
claysmoker's Avatar
St. Jude Donor '09-'11-'12-'13-'14
Do you have a part# on that tool? I'm coming up with J-5888, but no luck finding one.
Thanks,
Dave
Old 10-29-2010, 03:52 PM
Blue 396
Blue 396's Avatar
Not all that hard to do with practice,
Having a bearing press or arbor press will make the job a lot easier.
If you don't want to tackle this yourself you may be able to take your a-arms and bushings to a front end shop and they will do it for you, you'll need to have the front end aligned when you are done anyway.
Also IMO use Moog or another good grade of rubber bushings - don't go with urethane unless you plan to track the car. Be sure and check the ends of the shafts that run in the bushings, if the bushings are original and you have "squeaks" these may be worn. , be prepared to cut or torch the old ones out.
While you have it down you might as well do the ball joints - again with Moog parts - you do not want to do this twice.
Last bit of advise - if you have never done this before and still want to do it your self - pick up a used a-arm at a wrecking yard off of any older Nova, Camaro, Chevelle, Skylark, Cutlass ect and practice tearing it down b4 attempting to do it on your parts.
Happy Halloween !!!
Old 10-29-2010, 06:59 PM
JayWay
JayWay's Avatar
Yes, I did use the search function but did not find any specific details as to how to actually remove/replace the A-arm bushings on C2 suspension using specific tools and hydraulic press.
Thank you all for the information. Very much appreciated.
Jay
Old 10-29-2010, 07:20 PM
Bud2
Bud2
Support Corvetteforum!
Bud2's Avatar
Default Well....
You can burn them out or they can be drilled out. Just use a small drill bit and drill out all around the rubber. Lars has a tech paper on it too.
Bud.
Old 10-29-2010, 07:43 PM
1snake
1snake's Avatar
Bud.
And here's the link to it. http://www.lbfun.com/warehouse/tech_...%20rebuild.pdf
Jim
Old 10-29-2010, 09:14 PM
Blue 396
Blue 396's Avatar
Here's how
How do you know if your Corvette's upper control arm bushings are going bad? One of the easiest ways is to physically inspect them. If the rubber part of the bushing is deteriorated, cracked or even missing, it is time to replace them. If every time you pull forward or back up you hear a clunking sound or actually feel your Corvette’s front suspension move forward or back, replacement is the answer. Sometimes your Corvette will actually pull to the side that needs replaced every time you step on the brakes, acting just like a brake that is pulling.
If your Corvette's upper ball joint is bad, it will mimic some of the same conditions as the upper bushings. Since these are both very important front suspension parts, any problem should be corrected immediately.
The repair is not very hard but you will need access to a hydraulic press, hydraulic jack and jack stands. The whole replacement process can be done in one afternoon and as long as you follow your Corvette shop manual along with this article, it is fairly straight forward. Now with this in mind, let’s get started.
02: Start by jacking up your Corvette and placing the jack stands under the outer area of the lower control arms. You want the weight of your Corvette supported on the lower control arms.
03: Remove your Corvette's tire and wheel. Also remove the cotter key and nut from the upper ball joint. Now take a ball joint separator tool and separate the ball joint from the spindle. A few solid hits of a hammer should do it.
04: Keep the drum and spindle assembly from hanging by using a bungee strap. Hook it to your Corvette's frame or drag link.
05: Loosen the 2 nuts holding the upper control arm shaft in place and carefully remove the alignment shims from the front and back. Do not mix up the shims. After you have removed the nuts and shims, keeping the shims in order, then remove the control arm.
06: It is very important that you make a note of the number of shims in both the front and back of the control arm shaft. These are used to shim out the front end for proper alignment. Each shim is a particular width so they must be kept in order and replaced in the same location. I always tape the shims together and name their location.
07: Place the upper control arm in a vise and remove the upper ball joint. If the ball joint is the original one, it will be riveted in place. You will have to remove the rivets. This can be done by either drilling, using a die grinder, or using a chisel. The choice is up to you. I usually use a die grinder to grind off the head of the rivet. Then use a punch to drive the remaining stud out.
08: The new ball joint is held in place by bolts. These new bolts are larger than the rivet holes so you will have to enlarge them. Use a 21/64 drill bit to drill out the rivet holes to accept the new bolts.
09: Now remove the cap screws, lock washers, and collars from both ends of the control arm shaft.
10: Install a 3/8-24x2¼” cap screw in one end of the shaft. Place the control arm in a press and support one bushing end of the control arm shaft with a 1 11/16” socket. Now press out the bushing into the socket. Invert the control arm and repeat the process on the other bushing. Both of the old bushings should now be out of the control arm.
11: Thoroughly clean the control arm and refinish it with Eastwood’s Underhood Black. This will give it a new look.
12: Don’t laugh. This is the best way to store new bushings until you are ready to use them. Bushings that are kept in a freezer will contract and will install much easier. Once they warm up to room temperature, they will expand and be snug and secure.
13. Place the control arm in the press and install one bushing. Use a 1 5/16” socket to press the bushing into place. You will also have to support the inside of the control arm. You can see it here around the shaft. The easiest way to make this support is to use a 1 3/4” or 2” pipe (fence post will work). Cut it to fit between the inside flange of the control arm. Now cut approximately a 1” slot into the pipe. This will allow it to fit around the shaft and the bushings. Now you have a special control arm support. After you have installed the first bushing, install the cross shaft in the arm. Invert the arm in the press and then press in the second bushing. Make sure that the cross shaft can be turned by hand. It should not bind after it is installed.
14: The collar, lock washers and cap screws can now be installed. Snug them into place but do not tighten them. This will be done later.
15: Next you can install the new ball joint. Fit it into the control arm, install the bolts and nuts and torque them to 25 ft. lbs. NOTE: If you are rebuilding your Corvette for National Show Competition, you cannot bolt the ball joints back into place. You must have them riveted.
16: Re-install the control arm back onto the crossmember. Remember to have the mounting studs in position. Install the nuts onto the retaining studs. Then re-install the alignment shims making sure you replace them in their original position. When the shaft is installed, torque the cross shaft nuts to 65 to 75 ft. lbs.
17: Now install the rubber boot on the upper ball joint. Place the ball joint into the spindle and install the nut. Torque the ball joint stud to 42 to 47 ft. lbs. Align the hole in the stud and install the cotter key.
18: You can now lube the ball joint. Re-install the tire and wheel and lower the car to the ground.
19: After your Corvette is on the ground, bounce the front end of the vehicle. This will center the upper control arm bushings. Tighten the collar bolts to 35 to 40 ft. lbs.
20: For reference, here is what an upper control arm bushing looks like when the rubber has disintegrated.
21: This is the way it should look with the rubber compressed between the collar and the bushing.
22: Here is another helpful hint: Always replace the cross shaft alignment bolts whenever you remove the cross shaft. These bolts have a serrated area below the head and when they are removed, they lose some of the serration. When this is removed, they will lose some of the grip and will spin in the cross shaft when they are tightened.
Parts List:
Torque Specifications:
•Ball Joint To Control Arm - 25 Ft. lbs
•Ball Joint To Spindle - 42-47 Ft. lbs.
•Cross Shaft To Crossmember - 65-75 Ft. lbs
•Cross Shaft End Cap Screws - 35-40 Ft. lbs
Old 10-29-2010, 11:46 PM
JayWay
JayWay's Avatar
Many thanks to Bud2, 1snake and Blue396 for the additional information you provided.
At this point I believe I have sufficient knowledge and advice to confidently attack refurbishing the front suspension of my car.
Best Regards,
Jay
Old 10-30-2010, 01:19 AM
kskid
kskid's Avatar
J-5888-3 is the A arm support. A square plate with like 1/2 diameter of pipe welded on to support arm in the press so its does not get bent.
Old 11-01-2010, 02:52 PM
Tom454
Tom454's Avatar
Thanks,
Dave
Don't know if the special tools are still available.
The set is about 5 pieces.
1) as described by kskid
2) a spacer/brace to keep the upper arm from bending
3) a spacer to keep the lower arm from bending
4 & 5) two little spacers to keep the lower arm outboard ears from bending.
The spacer for the lower arm has a hole/notch cut in it to allow the eye on the shaft to fit through it.
The objective is to keep everything aligned so that when you are finished, the shafts rotate freely by hand in the bushings. If they don't rotate, then the arms are bent.
If interested, I can send pics.
It's a little bit bigger than 1/2" pipe.
Old 09-08-2013, 07:55 PM
dewhurstaj
dewhurstaj's Avatar
Default Feasible – UCA shaft to press UCA bushing?
Front passenger side of my 66 upper control busing is not properly pressed in the “UCA” upper control arm.
The rear bushing is fine.
I have both of the shaft bolts tight & the front UCA bushing is not properly seated.
Thus, can I use the control arm shaft as a press to properly seat the front UCA bushing?
Install a nut & washer on a longer shaft bolt, slug the bolt & tighten the nut pushing the washer on the bushing to properly seat it in the UCA.
I am trying to get this job complete w/o removing the UCA from the car. All parts are newly replaced urethane bushing.
Any help will be very much appreciated!
Thanks!
Andy
Old 09-13-2013, 07:56 AM
Tom454
Tom454's Avatar
Thanks!
Andy
I don't believe that would work. There would be nothing actually holding the UCA opposing the washers etc. The inner sleeve of the bushing backs against a lip on the shaft and will most likely just pull through to the front. The outer rubber lip will probably compress to the point of damage.
Old 09-14-2013, 09:10 AM
dewhurstaj
dewhurstaj's Avatar
Tom,
Thanks for the email. I tried my proposed "use the control are shaft as a vise w/ large washers & a longer bolt to press the bushing into the UCA" w/o success. The bolt tightened w/o the bushing seating into the UCA. The bushing is not rusted & It moved rather easy to insert the control are shaft.
"There would be nothing actually holding the UCA opposing the washers etc."
Can this be resolved?
Do you know of an easy way to press or seat the bushing into the UCA w/o removal?
Thanks!
Andy
Old 09-14-2013, 11:11 AM
Ron Miller
Ron Miller's Avatar
Thanks!
Andy
I believe "easy way" and "seat the bushing into the UCA w/o removal" are mutually exclusive terms.
Old 09-17-2013, 01:40 PM
Tom454
Tom454's Avatar
Tom,
Thanks!
Andy
Can't come up with a "Easy Button". I think you will have to remove the shaft and press the bushing... using the correct tool/spacer to avoid damaging the UCA.
To C2 A-arm bushing replacement
Quick Reply: C2 A-arm bushing replacement
