Go Back   Corvette Forum > C1 & C2 Corvettes, 1953 - 1967 > C1 & C2 Corvettes
Register Forgot Password?
Register Search Today's Posts Mark Forums Read FAQ Vendor Directory
Search
C1 & C2 Corvettes
General C1 Corvette & C2 Corvette Discussion, Technical Info, Performance Upgrades, Project Builds, Restorations Sponsored by
Flaming River
Industries
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C7 Parts & Accessories
C6 Parts & Accessories
C5 Parts & Accessories
C4 Parts & Accessories
C3 Parts & Accessories
C2 Parts & Accessories
C1 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 10-27-2010, 10:25 PM   #1
vettepoor
CF Senior Member
vettepoor's Avatar
Default Muncie popping out of gear
What is the likely cause for my muncie m21 popping out of gear? On a cruise this past weekend, I had this happen twice, both times when I was in 2nd gear and coming down hills. Is this most likely in the linkage adjustment or something worse? Thanks for any thoughts.
John
vettepoor is offline   Reply With Quote
Old 10-27-2010, 11:02 PM   #2
Dan Hampton
CF Senior Member
Dan Hampton's Avatar
One of three things or a combination thereof, but in all likelihood, your slider is not maintaining its engagement with the driven gear. The best solution for this is to replace it with a torque lock slider. That will eliminate the problem. I would also purchase a new internal hub to go with the slider. Worn engagement teeth on the gear, itself, can be a secondary cause, and given that gears are relatively inexpensive, I would consider replacing it, too. Since you have it disassembled, you might want to consider replacing the hub/slider for 3/4 gear, too.
No easy way to remedy the problem but to remove the transmission and tear it down.
Dan Hampton is offline   Reply With Quote
Old 10-27-2010, 11:05 PM   #3
KC John
CF Senior Member
KC John's Avatar
Is this something that can be done at home, or do you need any special tools to do the job?
I have the same problem on a B/W transmission.
KC John is offline   Reply With Quote
Old 10-28-2010, 08:03 AM   #4
DansYellow66
CF Senior Member
DansYellow66's Avatar
You do need to check the linkage adjustment before diving into the transmission. There is a slight chance it could be the linkage. You didn't say if you have a stock or Hurst shifter. The Hurst have shifter stop bolts to limit movement of the linkage cams and arms. If the one on the second and fourth gear is too tight the transmission gear and slider may not be fully engaging. I would check this because I believe it's often that third gear is the one that gets weak first and starts poping out of gear. Or maybe that was just my car.
DansYellow66 is offline   Reply With Quote
Old 10-28-2010, 08:23 AM   #5
Kerrmudgeon
CF Senior Member
Kerrmudgeon's Avatar
Location: The Great White North. Mellowing with age like fine wine!
I doubt if it's the shifter if it's happened over time. My B-W started doing this, only on deceleration, and when I dove into the cases, found all sorts of worn parts, and did a complete rebuild. And yes, there's no real special tools required, and if you are organized you can do it yourself. It was the first one I did, and it's never given me any trouble since, 20 years ago. K
Kerrmudgeon is offline   Reply With Quote
Old 10-28-2010, 08:30 AM   #6
Five Window
CF Senior Member
Five Window's Avatar
Rebuilding the tranny takes care, but would make a good winter project. I did mine a few years back. This site http://www.5speeds.com/muncie.htm is great. I used his video (a tape then, DVD now) and it helped a great deal. He was always available by phone if you had a question.
Check the linkage first, though.
Five Window is offline   Reply With Quote
Old 10-28-2010, 09:20 AM   #7
DZAUTO
CF Senior Member
I don't do social media stuff I Don't do it I Don't do it I Don't do it I Don't do it I Don't do it
Dan is 100% spot on!
I've been building 4spds (mostly Muncies) for 40+yrs, and when the Tork Loc sliders became available, it was an excellent "fix" for many trannys (Muncies and T10s) that ocassionally popped out of gear while decellerating. Another thing that is a MUST to check whild the tranny is out, is the pilot bushing in the end of the crankshaft---------------MANY people neglect to check/replace this VERY IMPORTANT cheap part!!!!!!!!!!!!!!
The Tork Loc sliders (photo comparrison below) have an additional machined back cut at each end of the splines. This back cut serves to "pull" the slider into the small engatement teeth of the gear, thus making a more secure engagement of the gear.
But, as Dan mentioned, if the engagement teeth of the affected gear are badly worn, then gear replacement is also advised.
Personally, based on your experience/description, I think a pair of Tork Loc sliders (PLUS a rebuild kit) while you have it apart, will extend the service life of your Muncie for as long as you own the car (or live ).
Click the image to open in full size.
Tom Parsons
__________________
Tom Parsons
DZAUTO is offline   Reply With Quote
Old 10-28-2010, 09:48 AM   #8
OldKarz
CF Senior Member
OldKarz's Avatar
Location: On the bank of the Columbia River..... Washington State
I had the same problem, ended up doing a rebuild and all is well.
OldKarz is offline   Reply With Quote
Old 10-28-2010, 10:04 AM   #9
MikeM
CF Senior Member
When I got my '63 some years ago, it was jumping out of second on decel.
The shift linkage was adjusted in such a way that the handle would come back too far aft in second, pinch the shift boot between the handle and console and keep it from going all the way into second.
You couldn't really feel it but the condition existed. No problem in fourth. A quick adjustment to hold the shift gate a little forward fixed the problem more than five years ago.
Maybe you'll get lucky.
MikeM is offline   Reply With Quote
Old 10-28-2010, 10:32 AM   #10
Dan Hampton
CF Senior Member
One last thing that you might want to think about, too, is replacing the detent spring in the side cover with a heavier spring. Larry at D & L Transmissions can provide one of those for you. GM made the change in the mid 60s (John Z might know when) but it serves to keep the shift levers more rigid and helps in preventing the shifter from popping out of gear.
Old 10-28-2010, 11:45 AM   #11
DZAUTO
CF Senior Member
Every rebuild that I do on an early tranny that has the spring with shorter, lighter coils, I replace it with the heavier spring that was on later trannys.
Many years ago when the springs were available from GM, I bought 50. I'm now down to about 4-5.
Tom Parsons
__________________
Tom Parsons
Reload this Page Muncie popping out of gear
Tags
3rd, 4th, coming, engagement, factory, fourth, gear, jumps, muncie, popping, pops, replacing, slider, sliders, tramsmission, transmission
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
