Roller Rockers under stock valve covers
Old 09-12-2010, 12:42 PM
woodsdesign
woodsdesign's Avatar
Default Roller Rockers under stock valve covers
Guys,
I have been thinking of installing roller rockers on my 65 L-79. I have been looking at Harland Sharps. Has anyone done this and used the stock valve covers? Also, do you see any advantage installing these.
Larry
Old 09-12-2010, 12:48 PM
bosshog8
bosshog8's Avatar
Your either going to need valve cover shims or several thick gaskets with reinforcement in between. Stock covers and stock gaskets won't cut it. If you have power brakes then you have to check clearance there also but it should be ok.
Old 09-12-2010, 12:58 PM
woodsdesign
Can you recommend a thick gasket or shim. Are they worth installing?
Old 09-12-2010, 01:01 PM
midyearvette
Support Corvetteforum!
midyearvette's Avatar
i would go with the comp cams roller tipped rockers..great for street reliability and no problems fitting a stock cover set up...
Old 09-12-2010, 01:47 PM
NOM61
NOM61's Avatar
I'll be installing a set of Comp ultra pro magnums shortly.
I think a spacer or tall covers are in my future.
DT
Old 09-12-2010, 01:59 PM
larrywalk
larrywalk's Avatar
Problem with a full roller rocker is that the poly-lock style rocker nut is too high to clear the underside of the stock valve cover. Unfortunately, there is no short poly-lock style rocker nut which doesn't stick above the top of the rocker stud (as far as I know).
Alternately, one can't use a self-locking nut because the slot in a full roller rocker is not wide enough.
I've used the Comp Cams roller-tipped rockers successfully for many years as long as the valve spring pressures at full open have not been above ~300 lb.
Old 09-12-2010, 02:58 PM
woodsdesign
I have stock valve springs. Are these OK?
Old 09-12-2010, 03:00 PM
Plasticman
Plasticman's Avatar
Absolutely.
Plasticman
Old 09-12-2010, 03:25 PM
bigearl56
bigearl56's Avatar
Default Question
NOM61 I am currently using Comp Cams roller tip rocker arms on a 427. I used two cork gaskits glued together and have plenty of clearance. Not sure about a small block?
Whats the story behind the MGA avatar?
Earl
Old 09-12-2010, 03:43 PM
NOM61
NOM61's Avatar
bigearl56,
These are full rollers with poly-locks. I'm going to use aluminum spacers.
The MGA is just me being contrarian.
I'm actually using it temporarily as a daily driver.
DT
Old 09-12-2010, 05:16 PM
BADBIRDCAGE
BADBIRDCAGE's Avatar
Received 1,963 Likes on 1,055 Posts
I run Comp Cams Pro Magnum full roller rockers on my small block. I have a set of Pep Boys chrome valve covers (stock in dimension) and run the THICK Fel Pro valve cover gaskets. Everything clears fine.
Old 09-12-2010, 06:01 PM
macs65
macs65's Avatar
I have these rockers with stock valve covers and a Fel Pro thick gasket, no problems with fit. Don't know how to put a photo on here but check out my garage there are photos of the rollers and covers.
Old 09-12-2010, 06:08 PM
L79vette
L79vette's Avatar
I have GM performance parts self-aligning roller rockers under stock valve covers, with Mr. Gasket thick cork gaskets.
Are they worth having? I don't know. I have seen a few dyno sheets that claimed something like 10HP, as I recall. I did not dyno mine with the rockers as the only change.
Old 09-12-2010, 06:18 PM
Vogie
Vogie's Avatar
Check Jeg's or Summit. They sell a cast aluminum spacer to fit under stock valve covers.
Old 09-12-2010, 06:47 PM
NEVERL8
NEVERL8's Avatar
I have Comp Cams pro magnum full rollers. I use Felpro performance cork/lam valve cover gaskets, .301" thick. Works great.
http://www.summitracing.com/parts/FPP-1604/
Old 09-12-2010, 11:54 PM
simard
simard's Avatar
Default Harlan Sharpe Roller Rockers
My 60 had these installed when I bought the car. Fit fine under the stock valve covers with standard gaskets. (1.5 to 1 ratio.)
Old 09-14-2010, 06:12 PM
GUSTO14
GUSTO14's Avatar
Received 1,962 Likes on 1,283 Posts
I ran this set up back in the late 60's on my '63 with no issues... I guess I just didn't know better back then.
Unfortunately this is what things tend to look like after 36 years in storage...
I'm now in the process of restoring the car to be period correct with a hydraulic roller and the same rockers. However this time I'm using these covers from PML...
The covers are much more substantial than the stock covers and provide about a half inch additional clearance.
http://www.yourcovers.com/valve_covers_11026.php
Good luck... GUSTO
Old 09-14-2010, 07:30 PM
Kerrmudgeon
Kerrmudgeon's Avatar
Received 4,583 Likes on 2,157 Posts
C1 of Year Finalist (appearance mods) 2019
Hey Wayne, beauty car eh! What size holley are you running? and what sort of HP is it making? Sorry to jack thread but I figure it's pretty well answered.
To Roller Rockers under stock valve covers
Quick Reply: Roller Rockers under stock valve covers
