Take a look at this front end...
Old 08-26-2010, 02:18 PM
RacrX
RacrX's Avatar
St. Jude Donor '08
Default Take a look at this front end...
Unless the steel structure of the car has been altered, can you think of any reason why I would not be able to re-install front bumpers?
Old 08-26-2010, 02:37 PM
Vogie
Vogie's Avatar
Where will you put the turn signals?
Old 08-26-2010, 02:39 PM
Blk63Vette
Blk63Vette's Avatar
Hello
Looks like they might have made a type of hitch to tow the Vette to drag races. My uncle made a bracket to hook up to his Truck when he drag raced his 1967 Big Block vette back in the day. You might have to remove brackets to put front bumper on..
Pete
Old 08-26-2010, 02:43 PM
66jack
66jack's Avatar
With just that one photo, It's hard to tell if the frame has been altered, I doubt it has.
The turn signals that are in the grill will be the biggest issue. "they are probably mounted to the frame "horns with bracket of sort.""
They will need to be put back in the original location or some other local that meets the vehicle code.
jack
Old 08-26-2010, 02:47 PM
RacrX
RacrX's Avatar
St. Jude Donor '08
Was thinking it would end up somewhat like this one:
Blk63Vette
Blk63Vette's Avatar
Looks like my brother 64 he had....Someone in the early 70s painted it purple and the front was painted like the head of a mako shark. Turn signal lights were taken out and fiberglassed over like this car...
I was told when the painter was doing the shark mural he was smoking alot of Mary J wannabe...The painter didnt remenber much about the paint job or inspiration for painting a sharks head upfront..
Old 08-26-2010, 02:55 PM
wmf62
wmf62's Avatar
St. Jude Donor '07
should be able to, just have to get the bumpers and bumper brackets to attach them to the frame.
turn signals can still attached to the grill like in the pic with the bumpers
Bill
Old 08-26-2010, 03:03 PM
Grey Ghost
Grey Ghost's Avatar
You should be able to see the brackets that connect to the cross member of the frame. Also the hole/bolt that passes through the fender.
Old 08-26-2010, 03:09 PM
RacrX
RacrX's Avatar
St. Jude Donor '08
GG- still waiting for an answer form the burgundy car...why it's taking him so long makes me suspicious. At least this guy is straightforward and is offering a buyback should it not turn out as described.
To Take a look at this front end...
Quick Reply: Take a look at this front end...
