painting oil pan
painting oil pan
Oil pan is chipping, I would like to strip it and paint it on the car. What would be the best way to strip it ? Any additional tips are welcome as usual.
Thanks Don
Thanks Don
Larry
I plan on painting the bottom of my engine, and replacing my V shields this winter. My game plan is to get the car up as high as I can on jacks, soak bottom motor with Gunk, apply thick, jel type, paint remover on pan, rinse off with 1500 psi pressure washer......then repeat these steps again. Mask off all around the oil pan, use aluminum foil on such hard to mask parts such as front end components. Spray paint oil pan.......paint the bottom of the motor with Bill Hirsch Chevy orange, and a painting sponge..... replace V shield's. I painted my engine compartment, including the firewall, inner fenders, and the top half of my motor using this method..... lots of newspaper and masking tape, but it came out very nice.
Have the pan Powder Coated
jack
jack
If installed correctly and with a bit of care, there's really no reason it should leak in the future.
Good luck... GUSTO
If my pan was not leaking I would hesitate to remove it also
On my wife's Camaro I used aviation type paint stripper with a cheap 1" paint brush.Let it soak and then wiped old paint off.Hand sanded the pan with 320grit.Then brake cleaner and degreaser.Mask it before before painting with duplicolor spray.
On my 62 I put a finned aluminum oil pan so that's one issue I don't have anymore.
