Help!! Starter not tunring over...and at work of all places.
Car has been turning over rough for most of the day for the 4-5 times I started it. Once it did nothing, and then started on the second try. Now It won't do anything... no click no nothing.
Is the starter toast? Any tricks to get me home for the day and in the garage?
Can you describe what you mean when you say 'rough'? Since you're at work and no doubt not going to be crawling under the car right now, all I can suggest is to check connections at the battery and at the solenoid if you can see or reach down in there. By the way, do you have an automatic trans? If so, maybe it's the Neutral Safety Switch which is there to prevent power from going to the starter unless you're in Park or Neutral.
Mike T.
Mike T.
Check battery connection
Check Starter connection
If they are good sometimes a hard rap on the starter with hammer will for some reason work, i did the hammer thing years ago on some car i had because i couldn't afford a starter.
might get you home
jack
Received 1,844 Likes
Swallow your pride and have several of your co-workers give you a push. Get it rolling and pop the clutch in 3-4 gear with the key on and it oughta' start.
Or maybe you can roll it off a hill?
Check these first.
might get you home
jack
might get you home
jack
It's worth a smack with a hammer. I was stranded on my yellow 66 back in March at the parts house. It was closing time, getting dark, and my starter was killing my battery at every attempt. Kept putting my jump box on, recharging the battery,but never enough to start the car. Tried to get a starter from the parts house I was broke down at. Could have it the next day. Ugh!! My car trailer was at a friends house 1 hour away, parts house shutting down the lights. No way I was going to leave my car there over night. Anyway, got a towel out of the back, my knock off lead hammer, crawled under the car and hit the starter with the lead hammer and started up. Kept her revved all the way home. No way I was going to let it shut off until safely home in the garage.
And BTW I'm sure my name was mud the night Jeff was in front of that parts house... since I had his trailer...
8 lb sledge!!!? You didn't have to crush it like a beer can. and I did not use your name in vain. Everything worked out to the good.
