BEST source for wiper motor repair/rebuild
Received 3,772 Likes
2023 C1 of the Year Finalist - Modified
2015 C1 of the Year Finalist
For as long as I've had the 56 (since 73), the wipers work great----------for a few cycles-----------then just quit. I turn off the wiper switch and eventually they come back on and then park. Sooooooooo, for those few times I have needed wipers, I turn them on, they make 2 cycles, I turn them off and wait a while before turning them on again for 2 cycles.
Well, when driving to the SACC Natls in Bowling Green, IT RAINED ALL THE WAY, FOR 800mi!!! And 2 ocassional cycles of the wipers just didn't cut it!
So, after all these years, I guess I need to break down and send it somewhere for a fix of the problem.
Who/where is the best source for wiper motor repairs???
Tom Parsons
Tom Parsons
Received 2,127 Likes
Our forum sponsor has a good reputation. Corvette Sprcialties of Maryland. Dennis
Hi Tom,
Steve Hackel did both my headlight and wiper motors. Top notch work and attention to detail and great turn around time. He does work for several of the vendors as well.
Chicago area 708-687-4183
THANKS for the leads. I'll check 'um out.
Tom Parsons
Tom Parsons
Brian gets my vote! Great work and a choice of a basic rebuild, rebuild with freshening up of the appearence, or a rebuild with an NCRS correct replating and refinishing of the entire motor.
Tom,
I'm going by memory because it's been several years, but, I think the wiper moter control is a pretty simple deal. It seams to me like something you might take a look at before you send it to anybody.
Larry
Larry
As I understand, unfortunately, the problem with my "intermitant" wipers is related to something INSIDE the housing where the contact points are. I've heard comments about somehow the contact points are burned or something like that and need to be replaced because they don't make good contact when they get hot. Since I'm not much of an electrical guru----------------ESPECIALLY with wipers, I'll have to defer that repair to an expert.
Tom Parsons
Larry,
Tom Parsons
Tom Parsons
Frank
ALSO, while we're on the subject of malfunctioning wipers, it SEEMS to me that at one time MANY years ago, I remember that it was said that this problem could be permanently cured by modifying the internal contacts so that the wipers were either Off or On full time on only ONE speed. Thus, when turned on, they STAYED on until turned off again.
Anyone know anything about this???
Tom Parsons
Tom Parsons
To Tom Parsons re windsheild wiper repair-resstoration
I just had Steve Hackel do my wiper motor (for 63swc) and it was very well done. working, finished like new and reasonable ($200 plus ). Take my suggestion, go with him and stop fiddling with your unit ( I gave up on mine after taking it aparrt, etc.) Regards, Abe G His phone # is 708-687-4183
Corvette Central sells the kit to eliminate the cables system. It replaces the motor and cables with a new motor and lever system. If I remember right, the motor mounts under the dash, not on the firewall. I think they developed the set up for their Project 57 car. The cost is around $500-$550.
St. Jude Donor '07
Bill
I called Steve. I was pleased with his response to my wiper problem, so I'll pull it off and send it to him.
THANKS
Tom Parsons
I LOVE CORVETTE FORUM!!!!!!!!!!!!!!!!!!!!!!!!
You know you can rebuild these yourself, don't you?.
the instructions are in the ST-12. Anybody that paints their lifter valley probably is capable of rebuilding a wiper motor.
Doug
Doug
Here is the CC kit:
http://www.parts123.com/parts123/yb.dll?parta~dyndetail~Z5Z5Z50000050e~Z5 Z5Z5ABWGN~P523.95~~~~S2ZL0T0ICW208118245 06a~Z5Z5Z5~Z5Z5Z50000050x
and here are the installation instructions:
http://www.parts123.com/corvettecentral/pdf/651085.pdf
Pretty straightforward but not cheap by any means...
Rain Gear is another (cheaper) option:
http://www.pacificwesterndesign.com/...rchevy5556.htm
St. Jude Donor '07
Here is the CC kit:
http://www.spwkits.com/products.php?c=2 $350.00
Bill
